Product
Brand
HP Replacement Laptop Keyboard
Quicklinx: BV7YWS00 Mfr#: 738697-031
This keyboard can be used as a replacement for your original laptop keyboard, if the original is damaged or broken. The keyboards are very easy to fit, with no soldering required.
HP - keyboard - UK
Keyboard
Layout
Pointing stick
ProBook 650 G1 (15.6 in)
Keyboard
Input Device
Layout
Pointing stick
1 x keyboard cable , 1 x pointing stick cable
RoHS
HP ProBook 650 G1 (15.6 in)
