Product
HP Quick Release Kit
Quicklinx: 981LWS00 Mfr#: EM870AA
Accessory Type: [N/A]
7 in stock
£30.75 ex VAT
£36.90 inc VAT
Standard delivery Delivered within 3-5 working days
A secure and easy-to-use mounting solution for your VESA-compliant HP thin clients, compatible HP flat panel monitors and other HP desktop products. Attach to any a compatible stand, bracket or wall mount and make the most of your workspace.
HP Quick Release - mounting kit
Mounting kit
13.2 cm x 1.7 cm x 16 cm
370 g
Recommended Use
Flat panel
Flat Panel Mount Interface
100 x 100 mm
Max Load Weight
10.9 kg
1 year warranty
HP 260 G2, 6300, Elite 8300, L2105, t430, t530, t5545, t628; Chromebox G2; EliteDesk 705 G3; EliteOne 800 G1, 800 G3; Flexible t520, t610; ProDesk 400 G3; ProOne 400 G2, 600 G1; Smart t410; Thin Client t5730; HPE t5145, t5540; Compaq Thin Client t5735; Flexible Thin Client t510
13.2 cm
1.7 cm
16 cm
370 g
AV Furniture
Mounting kit
Recommended Use
Flat panel
100 x 100 mm
Max Load Weight
10.9 kg
Limited warranty - 1 year
Compaq LA2405wg, S1921, S1922, S2021 , HP 2310ti, 260 G2, gt7720, gt7725, L1506, L1506s, L1706, L1706v, L1710, L1740, L1750, L1906, L1908w, L1908wm, L1910, L1940T, L1945w, L1945wv, L1950, L1950g, L2045w, L2105tm Touchscreen, L2208w, L2245w, L2245wg, L2445w, LA1905wg, LA2205wg, LE1851w, LE1901w, LE1901wm, LE2001w, LE2001wm, LE2201w, S1932, S1933, S2021, S2031, S2032, S2231a, S2331a, t430, t530, t5325, t5545, t5550, t5565, t5570, t5630, t5630w, t5740, t5740e, t5745, t628, v185w, v185ws, v216w, vc4820T, vc4825T, w17e, ZR30w , HP Chromebox G2 , HP EliteDesk 705 G3 (mini desktop) , HP EliteOne 800 G1, 800 G3 , HP Flexible t520, t610, t610 PLUS , HP ProDesk 400 G3 , HP ProOne 400 G2, 600 G1 , HP Smart t410 , HP Streaming Client st5548, st5738, st5742, st5747, st5748 , HP Compaq 6005 Pro (ultra-slim desktop), 6300 Pro PC, Elite 8300 PC, L2105tm, LA1751g, LA1905wg, LA1951G, LA2205wg, LA22f, LA2405wg, LE1711, LE1911, LE19f, s1922, S2021 , HP Compaq Business Desktop dx2009 , HP Compaq Thin Client t5135, t5530, t5720, t5725, t5730, t5730w , HPE t5145, t5540 , HPE Compaq Thin Client t5735 , HPE Flexible Thin Client t510
Brand: HP
Price Range Ex VAT: 0 - 50
