Mobility without compromise. Maximize productivity with the convenience of a tablet and the power of a notebook. Work confidently in or out of the office with commercial grade security and connectivity.
Designed for business
Optimized for productivity, the HP Pro x2 612 tablet packs in all the features you rely on including a large display with the built in connectivity, security, and high performance you need for everyday business. -
High performance tablet
Replace your traditional notebook with a tablet that lets you perform at your best with the choice of 4th Gen Intel Core processors, fast SSDs, and longer battery life when paired with the optional power keyboard. -
Security for business
Replace your traditional notebook with the HP Pro x2 612 G1. 2-in-1 solutions let you perform at your best with optional 4th generation Intel Core i3/i5 processors, fast solid state drives, and longer battery life when paired with the optional HP Pro x2 612 G1 Power Keyboard. -
Tablet or 2 in 1, you choose
Purchase your complete business mobility solution today. Choose the optional power keyboard with the optional HP UltraSlim Docking Station, or the travel keyboard for a lighter option. -
Featuring
Enjoy smooth and precise interaction with select models using the optional HP Pro x2 612 Wacom Pen with high performance pressure sensitivity and smart palm rejection technology.Functions as a full notebook by utilizing two USB 3.0 ports, DisplayPort, VGA and RJ45 on the HP Pro x2 612 G1 Power Keyboard. The Power Keyboard also supports enterprise docking with a side connector for the optional HP UltraSlim Docking Station.The HP Pro x2 612 Travel Keyboard helps you travel light and stay productive on the go.Easily collaborate with colleagues using the 12.5-inch diagonal FHD tablet with an optional Wacom Pen, Qualcomm Gobi 4G LTE, dual HD webcams, and HP Noise Reduction Software.Get to work virtually anywhere in the world with fast, reliable, and secure wireless connections using optional Qualcomm Gobi 4G LTE connectivity.
- HP Pro x2 612 G1 - 12.5" - Intel Core i5 - 4202Y - 8 GB RAM - 256 GB SSD - 4G LTE
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 8.1 Pro 64-bit
- Processor
- Intel Core i5 (4th Gen) - 4202Y / 1.6 GHz, up to 2 GHz / 3 MB Cache
- Memory
- 8 GB DDR3L (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 12.5" LED backlight touchscreen 1920 x 1080 / Full HD
- Graphics
- Intel HD Graphics 4200
- Input Device
- Keyboard, digitizer, touchpad, Tablet Pen
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Wireless Broadband (WWAN)
- 4G LTE
- Service Provider
- HP Mobile Connect
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- Dimensions (WxDxH) - tablet
- 30.7 cm x 20.95 cm x 1.28 cm
- 958.7 g
- Localisation
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Operating System
- Windows 8.1 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4202Y / 1.6 GHz
- Max Turbo Speed
- 2 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 12.5" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 300 cd/m²
- Ultra Slim Design, Corning Gorilla glass 3, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - Full HD
- Resolution
- 5 Megapixel (rear), 2 Megapixel (front)
- Camera Features
- 1080p Full HD movie recording, low light enhancement
- Sound
- Stereo speakers, two microphones
- Codec
- Realtek ALC3228
- High Definition Audio, DTS SOUND+
Input
- Volume control, spill-resistant
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Generation
- 4G
- Technology
- GPRS, EDGE, LTE, DC-HSPA+
- Controller
- HP lt4112 - M.2 Card
- Max Transfer Rate
- 100 Mbps
- Service Provider
- HP Mobile Connect
Navigation
- Receiver
- GPS/GLONASS
- Technology
- Lithium polymer
- Installed Qty
- 2
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- USB 3.0 , Headphone/microphone combo jack , 2 x USB 3.0 (on keyboard dock) , DisplayPort (on keyboard dock) , VGA (on keyboard dock) , Headphone/microphone combo jack (on keyboard dock) , Dock (on keyboard dock) , LAN (on keyboard dock)
- Memory Card Reader
- Yes (SD Card, SDHC Card, microSD, SDXC Card, microSDHC, microSDXC)
Software
- Software Included
- Cyberlink PowerDVD, Skype, HP Support Assistant, HP ePrint, HP Hotkey Support, Netflix, Foxit PhantomPDF Express, Absolute Data Protection (90 days trial), HP Spare Key, Microsoft Internet Explorer 10, Windows Defender, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Microsoft Internet Explorer 11, Drive Encryption, HP Manageability, Box.net
- Integrated Options
- Dockable
- Security
- Microphone with echo and noise-cancellation, HP SureStart, Full Volume Encryption, 1 USB 3.0 charging port
- Included Accessories
- Power adapter
- RoHS, WEEE
- Localization
- 958.7 g
- Dimensions (WxDxH) / Weight Details
- 31.7 cm x 23.95 cm x 2.33 cm - tablet with keyboard
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
