HP ProOne 600 G4 Core i5-8500 8GB 1TB All-In-One 20" Windows 10 Pro
Quicklinx: DVB9WS00 Mfr#: 4KX80EA#ABU
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i5
  • IEEE 802.11n
£838.06 ex VAT
£1,005.67 inc VAT
The HP ProOne 600 AiO is a sound investment that can be quickly deployed into demanding environments with a micro-edge, anti-glare, in-cell touch display, strong security, and comprehensive manageability features.
  • Sleek, modern design
    Featuring extensive cable management and a sleek design, this AiO suits the front desk or an owner's office. The micro-edge, anti-glare, in-cell touch 21.5-inch diagonal IPS display provides plenty of workspace.
  • Powerful options
    Get high-performance and expansion with 8th Gen Intel Core processors and optional features like Intel Optane memory, discrete graphics, USB Type-C , and a configurable I/O port.
  • Built on a secure foundation
    Protect your PC against the evolving malware threats of the future, with our self-healing, hardware-enforced, and manageable security solutions. From the BIOS to the browser HP Sure Start Gen4 and HP Sure Click help secure your PC.
  • Effective collaboration
    Communicate naturally with your PC using Cortana on Windows 10 Pro and collaborate with others using Skype for Business , HP Noise Cancellation, and an optional IR camera.
HP ProOne 600 G4 - all-in-one - Core i5 8500 3 GHz - 8 GB - 1 TB - LED 21.5" - UK
Personal computer - all-in-one
1 x Intel Core i5 (8th Gen) 8500 / 3 GHz (4.1 GHz) (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - PC4-21333
Storage Controller
SATA
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
4 in 1
Monitor
21.5" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller
Intel UHD Graphics 630
Camera
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 5.0
Keyboard
OS Provided
48.91 cm x 20.85 cm x 36.37 cm
5.78 kg
Limited warranty - parts and labour - 3 years
Personal computer
Product Form Factor
All-in-one - with height-adjustable stand
Built-in Devices
Stereo speakers, hood sensor
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Card Reader
4 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card, SDHC UHS-I Memory Card
Monitor
Monitor Type
LED - IPS
Touchscreen
Yes (10-point multi-touch)
Diagonal Size
21.5"
Native Resolution
Widescreen Display
Image Aspect Ratio
16:9
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Pixel Pitch
0.24795 mm
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Monitor Features
Anti-glare, 72% NTSC colour gamut, Projected Capacitive Touch (PCT) technology
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Speakers Included
2 x right / left channel
Camera
Camera
Resolution (MP)
1 Megapixel
Resolution
1280 x 720
Input Device
Mouse, keyboard
Keyboard
Wireless
Localization & Layout
Mouse
Wireless
Audio Input
Dual array microphone
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az, Bluetooth 5.0
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x external , 1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280/2230 (x4 mode)
1 x USB 2.0 - Type C , 4 x USB 3.1 Gen 1 (2 rear) (one of them is fast-charging) , 2 x DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Low halogen
Power adapter
Nominal Voltage
Power Provided
90 Watt
Efficiency
89% (115VAC), 89% (230VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), Absolute Persistence, HP Driver Packs, HP Device Access Manager, HP JumpStart, Skype for Business, HP Workwise, HP Noise Cancellation, HP Wireless Wakeup, HP System Software Manager (free download), HP PhoneWise, HP Sure Click, HP Client Security Suite Gen4, HP SureStart Gen4, Ivanti Management Suite, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 2
48.91 cm
20.85 cm
36.37 cm
5.78 kg
Shipping Width
63.2 cm
Shipping Depth
18.2 cm
Shipping Height
46.5 cm
Shipping Weight
7.34 kg
10 °C
35 °C
10 - 90%
HP ProOne 600 G4 Core i5-8500 8GB 1TB All-In-One 20 Bundle deal on HP ProOne 600 G4 Core i5-8500 8GB 1TB All-In-One 20" Windows 10 Pro
£1,017.92
saving £3.64
£937.23
Storage Type: HDD
Processor Model: I5-8500
Type: Personal computer
Case Style: All-in-one
Display: Integrated
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: 750 - 1000
