Design, productivity, and security. All in one. Set a new pace for your office productivity while demanding less from your IT team. Take on work more efficiently with a sleek PC designed to free your desk from clutter. Count on powerful built-in software that enhances security, manages updates, and automates backups. Your boss will praise you. Your IT staff will thank you.
Keep everything in sight
Watch your inbox while working on other tasks. There's plenty of screen room for all of your work with optional support for up to four external displays.Make the most of virtual conferencing. Bring work to life through immersive surround sound with deep, rich bass and crystal clear dialog using DTS Studio+ and an optional HD Webcam. -
Hassle-free security
HP Client Security suite helps you quickly and easily encrypt your hard drive, permanently delete unwanted or discarded data, restrict unauthorized access, and more.No more remembering passwords. HP Password Manager lets you quickly log in to various online accounts. Now your passwords can be longer and more secure. -
Do more by reclaiming your workspace
Stay organized and free up more room for work. This space-saving all-in-one has several stand options, and easily mounts on the wall. -
The hub of your mobile world
Speed up charging with a fast charging USB port. The nearly 2.8x stronger charging current helps compatible devices charge faster than standard USB 3.0 ports.Easily share your internet connection with your devices and help colleagues get online fast with HP Wireless Hotspot.Maintain tighter control over device security. Use the optional integrated near-field communications (NFC) capabilities to support custom applications such as advanced user authentication. -
Fast-track your performance
Quickly open new files and switch applications with less wait time thanks to solid-state drives and solid-state hybrid drive options. Get the latest processing technology with a choice of 4th generation Intel Core processors.Make better use of your workspace. HP ePrint makes wireless printing simple-no need for drivers.Get the team together. This Microsoft Lync qualified all-in-one is designed for productive virtual meetings with team members near and far. -
Plan with confidence
Get more out of your investment. The HP ProOne 600 G1 is designed for a long lifecycle, with platform stability up to 30 months.HP ProOne PCs are rigorously tested to help ensure reliability. During the HP Total Test Process, our PCs experience 115,000 hours of performance trials to help get you through your business day.Spend less time managing updates with HP Support Assistant. You can also safeguard your data with easy backup and recovery, using HP Recovery Manager.
- HP ProOne 600 G1 - all-in-one - Core i5 4590S 3 GHz - 4 GB - HDD 500 GB - LED 21.5" - TAA Compliant
- Personal computer - all-in-one - USB port control, chassis intrusion detection, tilt adjustment, swivel adjustment
- Localisation
- Processor
- Intel Core i5 (4th Gen) 4590S / 3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Monitor
- 21.5" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel HD Graphics 4600 Dynamic Video Memory Technology
- Audio Output
- Integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, Bing Toolbar, HP ePrint, Foxit PhantomPDF Express, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Box, Drive Encryption, HP Disk Sanitizer External Edition (free download)
- 52.19 cm x 19.56 cm x 42.68 cm
- 8.8 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Recommended Use
- Small business, corporate business
- Product Form Factor
- All-in-one
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q85
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 21.5"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Colour Gamut
- 72%
- Pixel Pitch
- 0.248 mm
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 2
Audio Output
- Integrated
- Max Sampling Rate
- 192 kHz
- DTS SOUND+
- Speakers Included
- 2 x right / left channel
Camera
- Form Factor
- Integrated
- Resolution (MP)
- 2 Megapixel
Input Device
- Mouse, keyboard
Keyboard
- Interface
- PS/2
Mouse
- Interface
- PS/2
Audio Input
- Stereo microphone
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2x2.5" / 1x3.5" shared
- Slots
- 1 (total) / 1 (free) x PCIe Half Mini Card , 1 (total) / 1 (free) x MXM 3.0 Type A , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x mSATA
- 4 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x microphone , 1 x headphones , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, CSA, UL, CCC, FCC, RoHS, WEEE, EuP Ready, CECP
- TAA Compliant
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS
- Efficiency
- 91%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software
Sustainability Information
- ENERGY STAR Certified
- 52.19 cm
- 19.56 cm
- 42.68 cm
- 8.8 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
