Easy to deploy, sleek, and feature-rich, the HP ProOne 440 23.8" All-in-One PC features a contemporary design with business-class performance, collaboration, security, and manageability features.
Let nothing stand in your way
Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day. -
Expansion that extends your investment
Maximize the life of your PC as your business requirements change with options that let you expand on your own schedule, including M.2 drives, SATA drives, and up to 32GB of DDR4 memory. -
Work without interruption
Keep productivity high and downtime low with HP BIOSphere Gen4 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks. -
Protect identities with HP Multi-Factor Authenticate Gen2
Fortify your security with up to three authentication factors including facial recognition. -
Super secure. Super protected
Guard your data, device and identity with HP Client Security Manager Gen4. -
Browse confidently
Help protect your PC from websites, attachments, malware, ransomware, and viruses with hardware-enforced security from HP Sure Click.
- HP ProOne 440 G4 - all-in-one - Core i5 8500T 2.1 GHz - 8 GB - HDD 1 TB - LED 23.8" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8500T / 2.1 GHz (3.5 GHz) (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- Monitor
- 23.8" - LED - 1920 x 1080 (Full HD)
- Graphics Controller
- Intel UHD Graphics 630
- Camera
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- HP Support Assistant, HP ePrint, HP Hotkey Support, Password Manager, HP Velocity, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), Absolute Persistence, HP Driver Packs, HP BIOS Config Utility, HP Device Access Manager, HP JumpStart, HP Workwise, HP Noise Cancellation, HP Wireless Wakeup, HP System Software Manager (free download), HP PhoneWise, HP Client Security Suite Gen4, HP SureStart Gen4, Ivanti Management Suite, HP Sure Run, HP Sure Recover, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 2
- 53.96 cm x 5.19 cm x 34.96 cm
- 4.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- All-in-one - with height-adjustable stand
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card
Monitor
- Monitor Type
- LED - IPS
- Diagonal Size
- 23.8"
- Native Resolution
- Widescreen Display
- Monitor Features
- Full HD anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 2 Megapixel
- Resolution
- Full HD
- 1920 x 1080 resolution
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
Audio Input
- Dual array microphone
- Interface (Bus) Type
- M.2 Card
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
- Wake on LAN (WoL), ACPI support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az, Bluetooth 5.0
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5"
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 , 1 (total) / 0 (free) x M.2 Card - 2230/2280
- 1 x USB 2.0 - Type C , 4 x USB 3.1 Gen 1 , 1 x DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Low halogen
- Power adapter
- Voltage Required
- Efficiency
- 89%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- Dimensions & Weight Details
- 53.96 cm - 5.19 cm - 34.96 cm - 4.5 kg - without stand , 53.96 cm - 20.85 cm - 39.23 cm - 6.37 kg - with stand
- 53.96 cm
- 5.19 cm
- 34.96 cm
- 4.5 kg
- Shipping Width
- 63.2 cm
- Shipping Depth
- 18.2 cm
- Shipping Height
- 46.5 cm
- Shipping Weight
- 7.93 kg
- 10 °C
- 35 °C
- 10 - 90%
Warranties (7)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Years On-Site | In Stock | £31.67 |
HP Care Pack Extended Service Agreement Next Business Day 2 Years | In Stock | £66.66 |
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £14.86 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £67.86 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £7.23 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £84.53 |
HP 3 Year Premium Care Desktop | In Stock | £102.69 |
Monitors (3)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E23 G4 23" 1920x1080 5ms USB VGA HDMI FHD Monitor | In Stock | £157.28 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
Keyboards and Mice (1)
HP Mouse X500 | In Stock | £9.16 |
Other bundles (2)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
