Easy to deploy, sleek, and feature-rich, the HP ProOne 400 G3 50.8 cm (20") All-in-One PC with business-class collaboration, optional touch, manageability, and security features is a sound investment.
Let nothing stand in your way
Be productive in any situation. Windows 10 Pro and powerful security, collaboration, and connectivity features from HP help you power through your day on the HP ProOne 400 AiO. -
Super secure. Super protected
Guard your data, device and identity with HP Client Security Suite Gen3. -
Work without interruption
Keep productivity high and downtime low with HP BIOSphereGen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks. -
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager. -
Several deployment options
Pair this space-saving AiO with the mounting option to fit your workspace and use case. -
Cut out the chatter
Suppress background noise including keyboard clicks with HP Noise Cancellation Software.
- HP ProOne 400 G3 - all-in-one - Core i5 7500 3.4 GHz - 4 GB - SSD 256 GB - LED 20" - UK
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i5 (7th Gen) 7500 / 3.4 GHz (, up to 3.8 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - PCI Express - NVM Express (NVMe)
- Optical Storage
- DVD-Writer
- Card Reader
- Monitor
- 20" - LED - 1600 x 900 (HD+) - 16:9
- Graphics Controller
- Intel HD Graphics 630 Dynamic Video Memory Technology
- Camera
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- OS Provided
- Windows 10 Home Single Language 64-bit Edition
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications
- 49.772 cm x 5.889 cm x 34.751 cm
- 5.61 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- All-in-one
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.4 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H270
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer - SATA
Card Reader
- Card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- LED - TN
- Diagonal Size
- 20"
- Native Resolution
- 1600 x 900 (HD+)
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Colour Gamut
- 72%
- Pixel Pitch
- 0.276 mm
- Image Brightness
- 250 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Anti-glare
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
- Speakers Included
- 2 x right / left channel
Camera
- Camera
- Resolution (MP)
- 1 Megapixel
- Resolution
- 1280 x 720
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
Audio Input
- Dual array microphone
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 M.2 Card - 2230 (x1 mode) , 1 M.2 Card - 2230/2280 (x4 mode)
- 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 2.0 (2 rear) (wake functionality) , 1 x DisplayPort , 1 x headphones , 1 x microphone , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x PS/2 keyboard , 1 x PS/2 mouse
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Low halogen
- Power adapter
- Power Provided
- 90 Watt
- Efficiency
- 89%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Home Single Language 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- Dimensions & Weight Details
- 49.772 cm - 5.889 cm - 34.751 cm - 5.61 kg - without stand
- 49.772 cm
- 5.889 cm
- 34.751 cm
- 5.61 kg
- Shipping Width
- 57.7 cm
- Shipping Depth
- 18.7 cm
- Shipping Height
- 45.2 cm
- Shipping Weight
- 6.75 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
