Easy to deploy, sleek, and feature-rich, the HP ProOne 400 50,8 cm (20") All-in-One PC with business-class collaboration, touch, manageability, and security features is a sound investment.
Simplify device management
Reduce the complexity of administration. Windows 10 Pro manageability features help you easily manage assets. -
Expand with ease
Easy access to critical parts, rigorous testing, and HP temperature control technology helps ensure your AiO withstands tough work environments. -
Several deployment options
Pair this space-saving AiO with the stand option to fit your workspace and use case. -
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software. -
Give your speakers a boost
DTS Studio Sound lets you make the most of virtual conferencing. -
Communication made easy
Make conferencing from your PC as simple as the touch of a button with the optional HP Conferencing Keyboard.
- HP ProOne 400 G2 - all-in-one - Core i3 6100T 3.2 GHz - 4 GB - HDD 500 GB - LED 20" - UK - TAA Compliant
- Personal computer - all-in-one
- Localisation
- Processor
- Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Monitor
- 20" - LED - 1600 x 900 (HD+) - 16:9 - touchscreen
- Graphics Controller
- Intel HD Graphics 530 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, CyberLink PowerDVD BD Edition, Windows Defender, HP Systems Software Manager (free download), HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, HP CIK for Microsoft SCCM (free download)
- 49.671 cm x 5.87 cm x 34.75 cm
- 5.45 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Product Form Factor
- All-in-one
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- LED - TN
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 20"
- Native Resolution
- 1600 x 900 (HD+)
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Colour Gamut
- 72%
- Pixel Pitch
- 0.276 mm
- Image Brightness
- 225 cd/m²
- Image Contrast Ratio
- 1000:1
- Monitor Features
- Projected Capacitive Touch (PCT) technology
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS Studio Sound
- Speakers Included
- 2 x right / left channel
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Wireless LAN Supported
- Wireless NIC
- Broadcom BCM943228Z
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.3x, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Skype Certified, IEEE 802.3az, Bluetooth 4.0
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin
- 4 x USB 3.0 (2 rear) (one of them is Always On) , 2 x USB 2.0 , 1 x DisplayPort , 1 x headphones , 1 x microphone , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- ACPI
- TAA Compliant
- Power adapter
- Voltage Required
- Power Provided
- 90 Watt
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- ENERGY STAR Certified
- 49.671 cm
- 5.87 cm
- 34.75 cm
- 5.45 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
