Product
Brand
HP Promo T520 SMRTZEROCORE 8GB 4G Thin Client
Quicklinx: DCXSWS00 Mfr#: 2DH78AT#ABU
Processor Type: GX-215JJ
Operating System: HP ThinPro
Installed Memory: 4GB
Hard Drive Capacity: 8GB
Storage Type: Flash
23 in stock
£190.14 ex VAT
£228.16 inc VAT
With a modern, new look and a small size, the HP t530 has raised the stakes for thin client design. Multiple deployment options allow this thin client to fit into any workspace.
HP t530 - tower - GX-215JJ 1.5 GHz - 4 GB - 8 GB
Thin client - tower
English / United Kingdom
1 x AMD GX-215JJ 1.5 GHz (2 GHz) (Dual-Core)
Processor Main Features
AMD Turbo CORE Technology
Cache Memory
1 MB L2 Cache
Cache Per Processor
1 MB
RAM
4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
Hard Drive
1 x flash 8 GB - M.2 - multi-level cell (MLC)
Graphics Controller
AMD Radeon R2E
GigE
OS Provided
HP ThinPro
3.5 cm x 20 cm x 20 cm
962.8 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years
Thin client
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L2 Cache - 1 MB
Cache Per Processor
1 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1866 MHz
Rated Memory Speed
2133 MHz
SO-DIMM 260-pin
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
Flash - M.2
1 x 8 GB
Multi-level cell (MLC)
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R2E
Video Interfaces
DisplayPort
Max Monitors Supported
2
Wake on LAN (WoL), DHCP support, PXE support
IEEE 802.1x
Slots
1 (total) / 0 (free) x SO-DIMM 260-pin , 1 (total) / 0 (free) x M.2 Card
1 x USB 3.1 Gen 1 (1 in front) , 1 x USB-C Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , Headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
UL, VCCI, GS, CB, CCC, FCC, RoHS, KCC, WEEE, ICES, MEPS, TCO Certified Edge, ERP, CECP, EMI/EMS Class B, low halogen
Power adapter
Nominal Voltage
Power Provided
45 Watt
Operating System / Software
OS Provided
HP ThinPro
OS Certified
HP ThinPro, Microsoft Windows Embedded Standard 7E, HP Smart Zero Core, Windows 10 IOT Enterprise
ENERGY STAR Certified
3.5 cm
20 cm
20 cm
962.8 g
10 °C
20 - 80% (non-condensing)
HP Promo T520 SMRTZEROCORE 8GB 4G Thin Client Bundle deal on HP Promo T520 SMRTZEROCORE 8GB 4G Thin Client
£346.52
saving £8.33
Storage Type: Flash
Type: Thin client
Case Style: Tower
Optical Storage: None
Brand: HP
Price Range Ex VAT: 150 - 300
