HP ProDisplay P240VA LED 23.8" Monitor 1920x1080 8MS
Quicklinx: C7X9WS00 Mfr#: N3H14AT#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 8ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£100.00 ex VAT
£120.00 inc VAT
Give your HP Pro PC content room to roam on the extra-large HP ProDisplay P240va Monitor, a sleek display that delivers essential presentation features and advanced connectivity for your everyday business productivity needs at a highly affordable price point.
HP ProDisplay P240va - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2739 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
57.12 cm x 19.12 cm x 41.64 cm
4.3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, CEL Grade 1, ISC, SEPA
3-year warranty
Display Type
Energy Class
Class A
28 kWh
19 W
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2739 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 94 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Japanese
HDCP, 72% colour gamut, Mercury free, arsenic-free glass
57.12 cm x 19.12 cm x 41.64 cm - with stand
4.3 kg
DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support, dual display support, cable routing slots
1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
32 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 57.12 cm - depth: 19.12 cm - height: 41.64 cm - weight: 4.3 kg , Without stand - width: 57.12 cm - depth: 5.5 cm - height: 35.55 cm - weight: 3.6 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
Response Time: 8ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 100 - 150
Price Range Ex VAT: 50 - 100
