Project your HP Pro PC content to a 58,4 cm (23") diagonal display with the HP ProDisplay P232 Monitor, which has a sleek design, essential presentation features, and advanced connectivity for your everyday business productivity, all at a highly affordable price point.
High-speed connection for FHD imagery
Experience stunning FHD picture quality, ultra-fast graphics refresh, and vivid colors from the DisplayPort connection, which also supports multiple monitor connections from a single PC. Get legacy device compatibility from the VGA connector. -
Create an efficient, easy-to-use workspace
Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features. -
Designed with the environment in mind
Reduce power consumption and help lower your costs with an intelligent, energy-efficient, low halogen design that is ENERGY STAR and TCO certified and EPEAT Gold registered.
- HP ProDisplay P232 - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Black
- 54.86 cm x 18.5 cm x 40.83 cm
- 4 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, TUV, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, S Mark, MEPS, TCO Certified Edge, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA
- Display Type
- Diagonal Size
- 23"
- Viewable Size
- 23"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Pixel Per Inch
- 96
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Video Bandwidth
- 170 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, 72% colour gamut
- Black
- 54.86 cm x 18.5 cm x 40.83 cm - with stand
- 4 kg
- VGA , DisplayPort (HDCP)
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Flat Panel Mount Interface
- 100 x 100 mm
- VESA interface support, dual monitor support
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- Drivers & Utilities, HP Display Assistant
- Dimensions & Weight Details
- Without stand - width: 54.86 cm - depth: 5.5 cm - height: 34.63 cm - weight: 3.4 kg
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £96.99 | in stock |
£198.80
