HP ProDisplay P232 23" 1920x1080 5ms VGA DisplayPort LED Monitor
Quicklinx: BKY2WS00 Mfr#: K7X31AA#ABU
Diagonal Size: 23in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
Hurry, only 3 left in stock!
£121.31 ex VAT
£145.57 inc VAT
Project your HP Pro PC content to a 58,4 cm (23") diagonal display with the HP ProDisplay P232 Monitor, which has a sleek design, essential presentation features, and advanced connectivity for your everyday business productivity, all at a highly affordable price point.
  • High-speed connection for FHD imagery
    Experience stunning FHD picture quality, ultra-fast graphics refresh, and vivid colors from the DisplayPort connection, which also supports multiple monitor connections from a single PC. Get legacy device compatibility from the VGA connector.
  • Create an efficient, easy-to-use workspace
    Attach your HP Desktop Mini, HP Chromebox, or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
  • Designed with the environment in mind
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient, low halogen design that is ENERGY STAR and TCO certified and EPEAT 2019 registered.
HP ProDisplay P232 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
54.86 cm x 18.5 cm x 40.83 cm
4 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, TUV, TUV GS, VCCI, BSMI, NOM, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, ICES, S Mark, MEPS, TCO Certified Edge, KC, CECP, CEL, EAC, CEL Grade 1, ISC, RCM, SEPA
3-year warranty
Display Type
Diagonal Size
23"
Viewable Size
23"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Pixel Per Inch
96
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Video Bandwidth
170 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut
54.86 cm x 18.5 cm x 40.83 cm - with stand
4 kg
VGA , DisplayPort (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support, dual monitor support
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m
Backlight Life
30,000 hours
Power Supply
Internal
24 Watt
Power Consumption Stand by
0.5 Watt
Included Software
Drivers & Utilities, HP Display Assistant
Dimensions & Weight Details
With stand - width: 54.86 cm - depth: 18.5 cm - height: 40.83 cm - weight: 4 kg , Without stand - width: 54.86 cm - depth: 5.5 cm - height: 34.63 cm - weight: 3.4 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
HP ProDisplay P232 23 Bundle deal on HP ProDisplay P232 23" 1920x1080 5ms VGA DisplayPort LED Monitor
£221.07
Diagonal Size: 23in
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 100 - 150
