HP ProDisplay P223 1920 x 1080 5ms  VGA DP LED 21.5" Monitor
Quicklinx: CN4BWS00 Mfr#: X7R61AT#ABU
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
£85.56 ex VAT
£102.67 inc VAT
  • Fabulous front-of-screen
    Get crisp image clarity for all your content on the 54.6 cm (21.5") diagonal screen with 1920 x 1080 resolution, and 3000:1 contrast ratio. 178-degree viewing angles mean everybody has a great view.
  • High-speed connectivity and FHD imagery
    Experience stunning FHD picture quality, ultra-fast graphics refresh, and vivid colors from the DisplayPort connection, which also supports multiple display connections from a single PC. Get legacy device compatibility from the VGA connector.
  • Create an efficient, easy-to-use workspace
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
HP ProDisplay P223 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
51.5 cm x 19.12 cm x 38.9 cm
3.5 kg
English / United Kingdom
Pricing Type
Promo
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, KCC, KC, CECP, EPA, TCO Displays, ISC, CEL Grade 2, SEPA, ICE
3-year warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102.4
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Mercury free, arsenic free
51.5 cm x 19.12 cm x 38.9 cm - with stand
3.5 kg
DisplayPort (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
Backlight Life
30,000 hours
Pricing Type
Promo
20 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Display drivers, HP Display Assistant
Dimensions & Weight Details
With stand - width: 51.5 cm - depth: 19.12 cm - height: 38.9 cm - weight: 3.5 kg , Without stand - width: 51.5 cm - depth: 5.49 cm - height: 32.7 cm - weight: 2.9 kg
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
HP ProDisplay P223 1920 x 1080 5ms  VGA DP LED 21.5 Bundle deal on HP ProDisplay P223 1920 x 1080 5ms VGA DP LED 21.5" Monitor
£184.73
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 50 - 100
