Your basket is empty
HP ProDisplay P222va 21.5" 1920x1080 8ms VGA DisplayPort LED Monitor
Quicklinx: BKRSWS00 Mfr#: K7X30AT#ABU
Put your HP Pro PC content front and center on an ample 54,6 cm (21.5") diagonal display with the HP ProDisplay P222va Monitor. The sleek design delivers essential presentation features and advanced connectivity for your everyday business productivity at a highly affordable price point.
HP ProDisplay P222va - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 5000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
51.8 cm x 18.66 cm x 37.92 cm
3.61 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA, TCO Displays, CEL Grade 1, ISC, SEPA
3 years warranty
Display Type
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102.4
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, input select
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut
51.8 cm x 18.66 cm x 37.92 cm - with stand
3.61 kg
DisplayPort (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
Stand
1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
Backlight Life
30,000 hours
Power Supply
Internal
24 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
Included Software
Drivers & Utilities, HP Display Assistant
Dimensions & Weight Details
With stand - width: 51.8 cm - depth: 18.66 cm - height: 37.92 cm - weight: 3.61 kg , Without stand - width: 51.8 cm - depth: 4.75 cm - height: 31.52 cm - weight: 2.94 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years - on-site
5 °C
35 °C
20 - 80% (non-condensing)
