Put your HP Pro PC content front and center on an ample 54,6 cm (21.5") diagonal display with the HP ProDisplay P222va Monitor. The sleek design delivers essential presentation features and advanced connectivity for your everyday business productivity at a highly affordable price point.
Be energy smart
Reduce power consumption and help lower your costs with an intelligent, energy-efficient, low halogen design that is ENERGY STAR and TCO certified and EPEAT Gold registered. -
Place it where you need it
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern, including the HP Adjustable Dual Display Stand, which holds two displays in a single-stand footprint. Select the head-only model if you don't need a stand. -
Complete the picture
Customize a total solution with options designed for your display. -
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software. -
Global reassurance
Rest assured that your IT investment is supported by a three-year standard limited warranty. Select HP Care Pack Services to extend your protection beyond the standard limited warranties.
- HP ProDisplay P222va - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 51.8 cm x 18.66 cm x 37.92 cm
- 3.61 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, KC, CECP, CEL, EPA, CEL Grade 1, ISC, SEPA
- 3-year warranty
- Display Type
- Diagonal Size
- 21.5"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Pixel Per Inch
- 102.4
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 24 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP
- Black
- 51.8 cm x 18.66 cm x 37.92 cm - with stand
- 3.61 kg
- DisplayPort (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities, HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 51.8 cm - depth: 18.66 cm - height: 37.92 cm - weight: 3.61 kg , Without stand - width: 51.8 cm - depth: 4.75 cm - height: 31.52 cm - weight: 2.94 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years - on-site
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
