HP ProDisplay P203 1660x900 20" LED Monitor
Quicklinx: DC5TWS00 Mfr#: X7R53AA#ABU
Diagonal Size: 20in
Max Resolution: 1600 x 900
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15)
£100.11 ex VAT
£120.13 inc VAT
Get essential presentation features and advanced connectivity for your PC or notebook with the HP ProDisplay P203 monitor.
  • Fabulous front-of-screen
    Enjoy crisp, clear HD color for all of your content on the 50.8 cm (20") diagonal screen with 1600 x900 resolution, 5 ms response time, and 1000:1 contrast ratio.
  • High-speed connectivity and HD imagery
    Experience stunning HD picture quality, ultra-fast graphics refresh, and vivid colors from the DisplayPort connection, which also supports multiple display connections from a single PC. Get legacy device compatibility from the VGA connector.
  • Create an efficient, easy-to-use workspace
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply and cable management features.
  • Be energy smart
    Reduce power consumption and help lower your costs with an intelligent, energy-efficient, low halogen design that is ENERGY STAR and TCO certified and EPEAT 2019 registered.
HP ProDisplay P203 - LED monitor - 20"
LED-backlit LCD monitor - 20"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
48.2 cm x 19.1 cm x 37.1 cm
3.3 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, TCO Displays, EAC, ISC, CEL Grade 2, SEPA, ICE
3-year warranty
Display Type
Diagonal Size
20"
Viewable Size
20"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.276 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
24 - 70 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
WLED
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Mercury free, arsenic free
48.2 cm x 19.1 cm x 37.1 cm - with stand
3.3 kg
DisplayPort (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand
Backlight Life
30,000 hours
17.8 Watt
Power Consumption Sleep
0.5 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 48.2 cm - depth: 19.1 cm - height: 37.1 cm - weight: 3.3 kg , Without stand - width: 48.2 cm - depth: 5.5 cm - height: 30.8 cm - weight: 2.7 kg
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
HP ProDisplay P203 1660x900 20 Bundle deal on HP ProDisplay P203 1660x900 20" LED Monitor
£199.87
Diagonal Size: 20in
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 100 - 150
