Complement your HP Pro PC with the HP ProDisplay P202va Monitor, a sleek display that delivers essential presentation features and advanced connectivity for your everyday business productivity at a highly affordable price point.
Designed with the environment in mind
Be a better consumer with a display that has environmentally responsible components that include low halogen, arsenic-free glass, and mercury-free backlights. -
Place it where you need it
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern, including the HP Adjustable Dual Display Stand, which holds two displays in a single-stand footprint. Select the head-only model if you don't need a stand. -
Complete the picture
Customize a total solution with options designed for your display. -
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software. -
Global reassurance
Rest assured that your IT investment is supported by a three-year standard limited warranty, and a stable product lifecycle and minimum one-year lifespan. Add HP Care Pack Services to extend your protection beyond the standard limited warranties.
- HP ProDisplay P202va - LED monitor - Full HD (1080p) - 19.53"
- LED-backlit LCD monitor - 19.53"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 5000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 47.41 cm x 17.59 cm x 35.76 cm
- 3.3 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, CEL Grade 1, ISC, SEPA
- Display Type
- Diagonal Size
- 19.53"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 96 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, input select
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Portuguese, Russian, Spanish, Japanese, Korean
- HDCP
- Black
- 47.41 cm x 17.59 cm x 35.76 cm - with stand
- 3.3 kg
- DisplayPort (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Input Voltage
- Power Consumption (Typical)
- 18.5 Watt
- Power Consumption Stand by
- 0.5 Watt
- On / Off Switch
- Included Software
- Drivers & Utilities, HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 47.41 cm - depth: 47.41 cm - height: 35.76 cm - weight: 3.3 kg , Without stand - width: 47.41 cm - depth: 5.3 cm - height: 29.21 cm - weight: 2.6 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
