Pair your HP Pro PC with the HP ProDisplay P202 Monitor, a sleek display that delivers essential presentation features and advanced connectivity for your everyday business productivity at a highly affordable price point.
HD image presentation
Enjoy crisp, clear HD color for all of your content on the 50,8 cm (20') diagonal screen with 1600 x900 resolution, 5 ms response time, and 1000:1 contrast ratio. -
Plan ahead
Get a stable product lifecycle and minimum one-year lifespan. This Global Series display is also available around the world, so you can deploy across your business. -
Place it where you need it
Free up valuable desk space-the integrated 100-mm VESA pattern supports wall or HP Single Monitor Arm mounting. -
Complete the picture
Customize a total solution with options designed for your display. -
Your monitor's new best friend
Design the screen for how you work with HP Display Assistant software. -
Global reassurance
Rest assured that your IT investment is supported by a three-year standard limited warranty. Select HP Care Pack Services to extend your protection beyond the standard limited warranties.
- HP ProDisplay P202 - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- Energy Class
- Class A
- Energy Consumption per Year
- 21.1 kWh
- Power Consumption (On mode)
- 14.5 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 5000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 48.2 cm x 18.66 cm x 35.92 cm
- 3.5 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, EAC, CEL Grade 1, ISC, SEPA
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 21.1 kWh
- Diagonal Size
- 20"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Pixel Per Inch
- 92
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 24 - 70 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- HDCP, Mercury free
- Black
- 48.2 cm x 18.66 cm x 35.92 cm - with stand
- 3.5 kg
- DisplayPort (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
- Backlight Life
- 30,000 hours
- Localisation
- Power Supply
- Internal
- Input Voltage
- 14.5 W
- Power Consumption (Typical)
- 17.8 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- HP Display Assistant
- Dimensions & Weight Details
- With stand - width: 48.2 cm - depth: 18.66 cm - height: 35.92 cm - weight: 3.5 kg , Without stand - width: 48.2 cm - depth: 4.75 cm - height: 35.92 cm - weight: 2.8 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
