Product
HP ProDisplay Companion Stand
Quicklinx: B00ZWS00 Mfr#: J7V21AA
Maximize small work spaces with an affordable HP ProDisplay Companion Stand, which enables you to create a compact desktop solution by combining an HP ProDisplay Monitor with your choice of platform.
  • Easy assembly
    Simply attach your HP ProDisplay head to the front of the stand and attach your HP Desktop Mini, Chromebox, Thin Client or USDT to the back of the monitor using the integrated HP Quick Release mounting plate.
  • Keep it clean and secure
    Store your PC power brick out of the way on the built-in tray. Use the optional HP Security Lock to help deter theft or tampering of the PC or display.
  • Work comfortably
    Find your best viewing position with adjustable tilt settings.
  • Rest easy
    Get the reassurance of a one-year parts replacement limited warranty.
HP Companion Stand - monitor stand
Monitor stand
23.6 cm x 19.2 cm x 11.9 cm
850 g
HP 260 G2; ProDisplay P191, P221
Monitor stand
Flat Panel Mount Interface
100 x 100 mm
23.6 cm - 19.2 cm - 11.9 cm
850 g
HP Quick Release
