Powered for business, the HP ProDesk 600 SFF features strong security, and comprehensive manageability features in a stylish and compact design for the modern workplace.
Powerful options
Get high-performance and expansion with 9th Gen Intel Core processors and powerful memory. -
Expansion that extends your investment
The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 600 SFF has two bays and two slots. -
Built on a secure foundation
Protect your PC against the evolving malware threats of the future, with our self-healing, hardware-enforced, and manageable security solutions. From the BIOS to the browser, HP Sure Start Gen5 and HP Sure Click help secure your PC. -
A long-term partner
Rest easy with a PC that goes the distance and undergoes 120,000 hours of HP's Total Test Process.
- HP ProDesk 600 G5 - SFF - Core i5 9500 3 GHz - 8 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i5 (9th Gen) 9500 / 3 GHz (4.4 GHz) (6-core)
- Processor Main Features
- Intel Turbo Boost Technology
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 8 GB (installed) / 128 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- SSD Cache
- 3D Xpoint (Optane) - 16 GB
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel UHD Graphics 630
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 27 cm x 29.6 cm x 9.5 cm
- 4.54 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 8 GB / 128 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 2 (empty)
- Configuration Features
- 2 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- SSD Cache
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Channel Qty
- 3
Optical Storage
- DVD-Writer DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2x2.5" / 1x3.5" shared
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2230/2280 (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 , 1 (total) / 1 (free) x PCIe 3.0 x16
- 4 x USB 2.0 (2 front, 2 rear) (one of them is charging) , 4 x USB 3.1 Gen 2 (2 front, 2 rear) , 2 x USB 3.1 Gen 1 , 1 x audio line-in , 1 x audio line-out , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) , 1 x USB-C 3.1 Gen 2 (1 in front) (charging)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
- Power supply
- Nominal Voltage
- Power Provided
- 180 Watt
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- HP Support Assistant, HP ePrint, HP Hotkey Support, Windows Defender, HP Secure Erase, HP Drive Packs (free download), HP BIOS Config Utility, HP Setup Integrated OOBE, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP JetAdvantage, HP Sure Click, HP Manageability & Integration Kit Gen3 (free download), HP BIOSphere Gen5, HP Client Security Manager Gen5, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense, HP Image Assistant Gen4
- ENERGY STAR Certified
- 27 cm
- 29.6 cm
- 9.5 cm
- 4.54 kg
- Shipping Width
- 39 cm
- Shipping Depth
- 23 cm
- Shipping Height
- 49.9 cm
- Shipping Weight
- 7.08 kg
- 5 °C
- 35 °C
- 5 - 90%
