HP ProDesk 600 G5 DM Intel Core i5-8500T 8GB 1TB Windows 10 Professional 64-bit
Quicklinx: DQGTWS00 Mfr#: 4HM75ET#ABU
  • Core i5
  • IEEE 802.11n
Future-ready reliability and performance
Designed to fit the modern workspace, the stylish and ultra-small HP ProDesk 600 Desktop Mini is a powerful and reliable PC with performance, security, and manageability features for your business.
Business-ready performance, nicely packaged
Power through your day with a solution you can flexibly configure with an 8th Gen Intel® Core™ processor and options that include Intel® Optane™ memory, SSD storage, and up to 32 GB of DDR4 memory.
Expansion that extends your investment
Maximize the life of your PC with options4 that let you expand on your own schedule, including dual M.2 slots which allow for SSD RAID, traditional SATA drives, and a configurable I/O port.
Place it where you need it
Take your footprint down to near zero with a PC that attaches behind an HP EliteDisplay, or mount and secure it almost anywhere with HP accessories.4 Declutter with USB-C™, short cables, and rear I/O ports that connect to a range of displays.
HP exclusive security and manageability
Protect against BIOS attacks with HP Sure Start Gen4. Help prevent data breaches and downtime with HP BIOSphere Gen48 and easily manage devices through Microsoft System Centre Configuration Manager with HP Manageability Integration Kit
  • Expansion that extends your investment
    The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 600 SFF has two bays, two slots, and two M.2 connectors.
  • Built on a secure foundation
    Protect your PC against the evolving malware threats of the future, with HP's self-healing, hardware-enforced, and manageable security solutions. From the BIOS to the browser HP Sure Start Gen4 and HP Sure Click help secure your PC.
  • Connection hub
    With 11 total USB ports including one USB Type-C, the HP ProDesk 600 SFF becomes a hub for all your devices in the office.
HP ProDesk 600 G4 - mini desktop - Core i5 8500T 2.1 GHz - 8 GB - HDD 1 TB - UK
Personal computer - mini desktop
Intel Core i5 (8th Gen) 8500T / 2.1 GHz (, up to 3.5 GHz, (6-core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
HP Recovery Manager, HP Support Assistant, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Secure Erase, HP Manageability, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Credential Manager, HP Client Catalogue (free download), HP Driver Packs, HP Device Access Manager, HP JumpStart, HP Noise Cancellation, HP System Software Manager (free download), HP PhoneWise, HP Sure Click, HP BIOSphere Gen4, HP Client Security Suite Gen4, Power On Authentication, HP SureStart Gen4, Ivanti Management Suite, HP Management Integration Kit for Microsoft System Center Configuration Manager Gen 2
17.7 cm x 17.5 cm x 3.4 cm
1.25 kg
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.1 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q370
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
Memory Specification Compliance
PC4-21333
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Interface (Bus) Type
M.2 Card
Ethernet Controller
Intel I219-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 5.0
Bays
1 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2230/2280 (x4 mode)
3 x USB 3.1 Gen 1 (1 front, 2 rear) (two of them with wake functionality) , USB 3.1 Gen 2 (1 front, 2 rear) , 2 x DisplayPort , 1 x VGA , 1 x USB-C 3.1 Gen 2 (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front)
HP Desktop Mini Vertical Chassis Stand
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
RoHS, WEEE, low halogen
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
17.7 cm
17.5 cm
3.4 cm
1.25 kg
Shipping Width
49.7 cm
Shipping Depth
12.8 cm
Shipping Height
22.3 cm
Shipping Weight
2.97 kg
5 °C
35 °C
10 - 90% (non-condensing)
