The HP ProDesk 600 MT/SFF delivers value with a balance of performance and expandability for businesses with commercial-class productivity, reliability, security, and manageability needs.
Let nothing stand in your way
Help secure the future of your modern business. Modern PCs from HP make the most of Windows 10 Pro to help protect you from today's security threats and maximize management and productivity features for business. -
Efficient manageability
Help manage the fleet with Intel Standard Manageability and reduce the burden on IT resources with HP's Common Core BIOS that allows standard manageability across HP Desktops and HP Notebooks. -
Reliability for the long haul
Extend your business investments with a long life cycle and platform stability. -
Communication made easy
Make conferencing from your PC as simple as the touch of a button with the optional HP Conferencing Keyboard. -
Expand with ease
Give yourself room to grow with ease with multiple expansion slots, ports and connectors. -
Partner with HP to help you save time and money
HP helps you preserve your time and optimize your resources with expert configuration and deployment services that bring you fast, accurate, and globally standardized IT solutions.
- HP ProDesk 600 G2 - SFF - Core i3 6100 3.7 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- CyberLink Power2Go, HP Recovery Disc Creator, Skype, Windows 7 Professional 64-bit recovery DVD, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, Absolute Persistence, HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager
- 33.8 cm x 37.9 cm x 10 cm
- 7.6 kg
- Pricing Type
- Promo
- TAA Compliant
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q150
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS SOUND+
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 3.5" x 1/3H , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 3 (total) / 3 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin
- 4 x USB 2.0 (2 front, 2 rear) (one of them is Always On) , 6 x USB 3.0 (2 front, 4 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, Common Criteria EAL4+
- Pricing Type
- Promo
- TAA Compliant
- Power supply
- Voltage Required
- Power Provided
- 200 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
- 33.8 cm
- 37.9 cm
- 10 cm
- 7.6 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
