Equipped with the latest business-class performance and security features the HP ProDesk 600 Desktop Mini works with a complete line of accessories creating a smart solution for your work space.
Let nothing stand in your way
Help secure the future of your business. PCs from HP make the most of Windows 10 Pro to protect you from today's security threats and maximize management and productivity features for business. -
Ready to go the distance
The HP ProDesk 600 Desktop Mini endured 120,000 hours of rigorous testing during the HP Total Test Process. This combined with HP temperature controls helps provide reliability for your work environment. -
Green with envy
Keep an available ENERGY STAR certified PC on and updated with low energy consumption. -
Heavy security, exceptionally managed
HP BIOSphere is your security toolkit to safeguard and manage critical business data and devices. -
Reset the performance curve
Increase storage and performance with an optional powerful HP Turbo Drive that handles your growing and complex workloads. -
Consistently across the globe
Get the same HP configuration across the globe for your international business, available in more than 180 countries where HP conducts business.
- HP ProDesk 600 G2 - mini desktop - Core i5 6500T 2.5 GHz - 4 GB - SSD 128 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6500T / 2.5 GHz (, up to 3.1 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 530 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, HP CIK for Microsoft SCCM (free download)
- 17.5 cm x 17.7 cm x 3.4 cm
- 1.3 kg
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Built-in Devices
- Hood sensor
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q150
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS SOUND+
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Wireless LAN Supported
- Wireless NIC
- Broadcom BCM943228Z
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, Skype Certified, IEEE 802.3az, Bluetooth 4.0
- Bays
- 1 (total) / 0 (free) x internal 2.5" x 1/8H
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x M.2 Card (x4 mode) , 2 (total) / 1 (free) x SO-DIMM 260-pin
- 6 x USB 3.0 (2 front, 4 rear) , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.0 (1 in front)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, CCC, RoHS, WEEE, CECP, SEPA
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- Efficiency
- 89%
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- 17.5 cm
- 17.7 cm
- 3.4 cm
- 1.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
