Productivity and manageability in one. Give busy workers the edge they need to stay ahead. This PC's solid-state hybrid drive responds to the speed of work and opens applications right away. Powerful security and business-class management software frees up IT staff time.
Less waiting around
Speedy and responsive to keep pace with your multitasking. Quickly open new files and switch applications with less wait time, thanks to an optional solid-state hybrid drive.Power through your day with greater speed and performance. Get the latest in processing technology with your choice of 4th generation Intel Core processors.Easily share your internet connection with your devices and help colleagues get online fast with HP Wireless Hotspot. -
Keep everything in sight
Watch your inbox while working on other tasks. There's plenty of screen room for all of your work with support for multiple displays.Make the most of virtual conferencing. Bring work to life through rich sound and video with DTS Sound+ and an HD webcam.Keep your most important devices easily connected. Access and transfer data fast with two front USB 3.0 ports.Share presentations, videos, and other content-no cables needed. WiDi Intel Wireless Display lets you connect your ProDesk to projectors and other WiDi-ready devices.Put in more face time. You're ready for web chats and conferences with Skype pre-configured on your HP ProDesk 600 G1. It's almost as good as being there. -
Hassle-free security and management
HP Client Security software suit helps you quickly and easily encrypt your hard drive, permanently delete unwanted or discarded data, restrict unauthorized access, and more.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks and other security threats, and is designed to help prevent data loss and reduce downtime.You can help safeguard your data with easy backup and recovery, using HP Recovery Manager.Securely store all of your passwords and speed up access to your favorite password protected applications with HP Password Manager.Get right to the updates you need and spend less time managing updates with HP Support Assistant. -
Plan with confidence
Get more out of your investment. The HP ProDesk 600 G1 is designed for a long lifecycle, with platform stability up to 30 months.HP ProDesk PCs are rigorously tested to help ensure reliability. During the HP Total Test Process, our PCs experience 115,000 hours of performance trials to help get you through your business day.Add a little style to the workplace. HP business PCs feature a new industrial design with rounded edges and other features to help the system look newer for longer.
- HP ProDesk 600 G1 - tower - Core i5 4590 3.3 GHz - 4 GB - HDD 500 GB - TAA Compliant
- Personal computer - tower - administrator password, power-on password, serial port I/O control, USB port control, DriveLock, Intel Standard Manageability, Intel Identity Protection Technology (Intel IPT), Setup Password
- Localisation
- Processor
- Intel Core i5 (4th Gen) 4590 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 4600 Dynamic Video Memory Technology
- Audio Output
- Stereo - integrated
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Windows 7 Professional 64-bit recovery DVD, Microsoft Security Essentials, HP Support Assistant, Bing Toolbar, HP ePrint, PDF Complete Corporate Edition, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Box, Drive Encryption, HP Disk Sanitizer External Edition (free download)
- 17 cm x 44.2 cm x 39.9 cm
- 9.3 kg
- TAA Compliant
- Environmental Standards
- ENERGY STAR Qualified
- Personal computer
- Recommended Use
- Small business, corporate business
- Product Form Factor
- Tower
- Built-in Devices
- Solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel Q85
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA - integrated
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Mouse
- Interface
- USB
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Remote Management Protocol
- ASF 2.0
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 1 (free) x external 3.5" , 2 (total) / 1 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 1 (free) x PCIe x16 , 3 (total) / 3 (free) x PCIe x1 , 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin
- 6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.0 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 2 x DisplayPort , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Administrator password, power-on password, serial port I/O control, USB port control, DriveLock, Intel Standard Manageability, Intel Identity Protection Technology (Intel IPT), Setup Password
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE
- TAA Compliant
- Power supply
- Voltage Required
- Power Provided
- 320 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 92%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence
- OS Certified
- Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
- Software
Sustainability Information
- ENERGY STAR Certified
- 17 cm
- 44.2 cm
- 39.9 cm
- 9.3 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
