HP ProDesk 600 G1 DM Intel Core i5-4360 4GB 500GB Windows 7 Professional 64-bit
Quicklinx: BL12WS00 Mfr#: K1B19AW#ABU
  • Core i3
  • IEEE 802.11n
  • Microsoft Windows 7 Professional 64-bit Edition
  • Red Hat Enterprise Linux
Productivity and manageability in one. Give busy workers the edge they need to stay ahead. Powerful security and business-class management software frees up IT staff time.
  • Big power
    Smaller than some desk phones, this Desktop Mini can fit almost anywhere vertically or horizontally. The clean, easily serviceable design with integrated wireless antenna allows flexible deployment options to help optimize the workspace.Be up to 35% more productive by adding up to three independent displays using the integrated DisplayPort with Multi-Stream video outputs.Set up the HP ProDesk 600 G1 Desktop Mini in almost any spot or easily attach to several optional peripheral devices using the integrated VESA mount.The HP ProDesk 600 Desktop Mini G1 withstands 115,000 hours of the HP Total Test Process so you get confidence built right in.Easily service the HP ProDesk 600 G1 Desktop Mini. A single thumb screw provides fast access to clearly identifiable and serviceable components.
  • Full ProDesk functionality
    Keep productivity high and downtime low with HP BIOSphere firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.Power through your day with speed and performance. Get the latest in processing technology with your choice of 4th generation Intel Core processors.Take advantage of new drive technology with an optional M.2 PCIe solid state hard drive module, the internal 2.5" SSD, or dual drive configurations for more local storage.Make the most of virtual conferencing. Bring work to life through rich sound and video using DTS Studio Sound Audio software.Put in more face time. You're ready for web chats and conferences with Skype pre-configured on your HP ProDesk 600. It's almost as good as being there.
  • Solid security
    HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.HP Secure Erase removes the contents of a hard drive for repurposing or reassignment.Get extra protection with secured storage and ensured platform integrity thanks to the Trusted Platform Module security chip used by the BIOS and the Operating System.Keep sensitive information in safe hands. HP Trust Circles helps protect your data by ensuring that only assigned contacts can access critical files.
  • Green with envy
    The low energy consumption levels of this ENERGY STAR qualified and EPEAT Gold certified PC supports 24/7 operations. Consuming less than 8W of power at idle your Desktop Mini can be always on and always updated.
HP ProDesk 600 G1 - mini desktop - Core i3 4360T 3.2 GHz - 4 GB - HDD 500 GB - UK - TAA Compliant
Personal computer - mini desktop - administrator password, power-on password, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT), Setup Password
Intel Core i3 (4th Gen) 4360T / 3.2 GHz (Dual-Core)
Cache Memory
4 MB
Cache Per Processor
4 MB
RAM
4 GB (installed) / 16 GB (max) - DDR3 SDRAM - non-ECC - PC3-12800
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 4600 Dynamic Video Memory Technology
Audio Output
Stereo - integrated
1GbE, 802.11a, 802.11b/g/n
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Support Assistant, Bing Toolbar, HP ePrint, PDF Complete Corporate Edition, Microsoft Internet Explorer 10, Device Access Manager, HP Client Security, HP PageLift, HP File Sanitizer, Drive Encryption, Box.net, HP Disk Sanitizer External Edition (free download)
17.5 cm x 17.7 cm x 3.4 cm
1.3 kg
TAA Compliant
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Recommended Use
Small business, corporate business
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.2 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q85
Cache Memory
Installed Size
4 MB
Cache Per Processor
4 MB
RAM
Installed Size
4 GB / 16 GB (max)
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS SOUND+
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Ethernet Controller
Intel I217-LM
Wireless LAN Supported
Wireless NIC
Intel Wireless-N 7260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x SO-DIMM 204-pin , 2 (total) / 1 (free) x M.2 Card , 1 (total) / 0 (free) x CPU
4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 , 1 x VGA , 2 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Administrator password, power-on password, USB port control, DriveLock, Intel Identity Protection Technology (Intel IPT), Setup Password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE
TAA Compliant
Power adapter
Power Provided
65 Watt
Efficiency
87%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
OS Certified
Red Hat Enterprise Linux, SUSE Linux Enterprise Desktop 11
Software
Sustainability Information
ENERGY STAR Certified
17.5 cm
17.7 cm
3.4 cm
1.3 kg
10 °C
35 °C
10 - 90% (non-condensing)
