Designed to fit the modern workspace, the small, reliable, and secure HP ProDesk 400 is a powerful PC with performance that's scalable to grow with the business.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful HP ProDesk 400 SFF with built-in security, collaboration, and connectivity. -
Super secure
HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users. -
Work without interruption
Keep productivity high and downtime low with HP BIOSphere Gen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks. -
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager. -
Convenient, always-on, customized, free support
Enjoy always-on, included self-help support built right into your PC, for the life of your PC.
- HP ProDesk 400 G4 - SFF - Core i3 7100 3.9 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 630 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications
- 27 cm x 29.6 cm x 9.5 cm
- 4.6 kg
- Pricing Type
- Promo
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.9 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel H270
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- DVD±RW (±R DL) DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5"
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode)
- 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 4 x USB 2.0 (two of them with wake functionality) , 1 x VGA , 1 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, Common Criteria EAL4+
- Pricing Type
- Promo
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- 27 cm
- 29.6 cm
- 9.5 cm
- 4.6 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
