HP ProDesk 400 Intel Core i3 6100 4GB 128GB Windows 10 Pro/Windows 7 Pro
Quicklinx: C1TMWS00 Mfr#: T4R73ET#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
Give your business the strong foundation it needs for growth with the affordable and reliable HP ProDesk 400 SFF. Designed with essential security and manageability features, the HP ProDesk 400 helps keep your business growing.
New powerful processors
New 6th Gen Intel® Core™ processors bring powerful processing with Intel® HD 530 Graphics. Available DDR4 memory helps meet the demands of today’s businesses.
Tested to go the distance
HP ProDesks are rigorously tested to help ensure reliability. During the HP Total Test Process, PCs experience 120,000 hours of performance trials to help get you through your business day.
Security from the start
HP BIOSphere and HP Client Security boost security and keep critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
Make the smart investment
The HP ProDesk 400 SFF helps affordably build a solid IT infrastructure for your growing business and fits in smaller workspaces for easy deployment.
  • Let nothing stand in your way
    Help protect from today's security threats and maximize management and productivity features for business with Windows 10 Pro.
  • Simplify device management
    Activate, configure, patch, and update your devices from a single console.
  • Communication made easy
    Make conferencing from your PC as simple as the touch of a button with the optional HP Conferencing keyboard.
  • Connect to more capabilities
    Multiple displays have shown to help increase productivity by 35% and the HP ProDesk 400 SFF allows you to connect two optional HP Pro Displays right out-of-the-box.
  • Green with envy
    Reduce energy consumption and costs with ENERGY STAR and EPEAT Gold certified configurations.
  • Valuable support at your service
    Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that's available 24x7, covering multiple brands, devices and operating systems.
HP ProDesk 400 G3 - SFF - Core i3 6100 3.7 GHz - 4 GB - SSD 128 GB - UK
Personal computer - small form factor
Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
4 GB DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - SATA 6Gb/s
Optical Storage
DVD SuperMulti
Graphics Controller
Intel HD Graphics 530
Audio Output
Stereo
GigE
Keyboard
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
Software Included
CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, CyberLink PowerDVD BD Edition, Intel Wireless Display, HP Client Security, HP Security Manager, Drive Encryption, HP BIOSphere, HP Client Security Manager
9.5 cm x 29.95 cm x 27 cm
4.43 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Clock Speed
3.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB
DDR4 SDRAM
Effective Memory Speed
2133 MHz
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
SSD
1 x 128 GB
Interface Type
SATA 6Gb/s
3D V-NAND Technology
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
High Definition Audio, DTS SOUND+
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" / 3.5" shared
Slots
1 (total) / 1 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin
4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, Common Criteria EAL4+
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Software
9.5 cm
29.95 cm
27 cm
4.43 kg
