Designed to fit the modern workspace now and in the future, the small, reliable, and secure HP ProDesk 400 SFF is a powerful PC with performance that's scalable to grow with your business.
Powerful options
Power through your day with high-performance 8th Gen Intel Core processors unleashed by optional Intel Optane memory and discrete graphics. -
Expansion that extends your investment
The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 400 SFF has two bays and two half-height slots, and optional ports to connect up to three HP displays. -
Connection hub
With 8 total USB ports and optional Bluetooth connectivity, the HP ProDesk 400 SFF becomes a hub for all your devices in the office. -
Tested and ready
The reliable HP ProDesk 400 SFF experienced 120,000 hours of the HP Total Test Process and now has an optional dust filter to help extend the life of your PC by reducing airborne particulate intake in the most demanding work environments.
- HP ProDesk 400 G5 - SFF - Core i5 8500 3 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i5 (8th Gen) 8500 / 3 GHz (4.1 GHz) (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 9 MB
- Cache Per Processor
- 9 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel UHD Graphics 630
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 27 cm x 29.6 cm x 9.5 cm
- 4.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 9 MB
- 9 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 2 (total) / 2 (free) x internal 2.5"
- Slots
- 1 (total) / 1 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x M.2 Card - 2230/2280 , 1 (total) / 1 (free) x M.2 Card - 2230
- 4 x USB 3.1 Gen 1 , 4 x USB 2.0 , 1 x VGA , 1 x DisplayPort , 1 x headphones/microphone , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x serial , 1 x PS/2 keyboard / mouse
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- CCC, CECP, SEPA
- Power supply
- Nominal Voltage
- Power Provided
- 180 Watt
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP BIOS Config Utility, HP JumpStart, HP Workwise, HP Noise Cancellation, HP BIOSphere Gen3, Native Miracast, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications, HP Wireless Wakeup
- ENERGY STAR Certified
- 27 cm
- 29.6 cm
- 9.5 cm
- 4.6 kg
- Shipping Width
- 39.9 cm
- Shipping Depth
- 49.9 cm
- Shipping Height
- 23 cm
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
