Designed to fit the modern workspace now and in the future, the stylishly designed, reliable, and secure HP ProDesk 400 MT is a powerful PC with scalable performance that can grow with your business.
Powerful options
Power through your day with a high-performance 8th Gen Intel Core processor and options that include Intel Optane memory, SSD storage, and up to 32 GB of DDR4 memory. -
Expansion that extends your investment
The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 400 MT has three bays and three full-height slots, and optional ports to connect to up to three HP displays. -
Connection hub
With eight total USB ports and optional Bluetooth connectivity, the HP ProDesk 400 MT becomes a hub for all your devices in the office. -
Tested and ready
The reliable HP ProDesk 400 MT experienced 120,000 hours of the HP Total Test Process and now has an optional dust filter to help extend the life of your PC by reducing airborne particulate intake in the most demanding work environments.
- HP ProDesk 400 G5 - micro tower - Core i7 8700 3.2 GHz - 8 GB - HDD 1 TB - UK
- Personal computer - micro tower
- Localisation
- Processor
- Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 8 GB (installed) / 16 GB (max) - DDR4 SDRAM - non-ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel UHD Graphics 630
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 17 cm x 27.4 cm x 33.8 cm
- 5.47 kg
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Micro tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 8 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 3.5" , 1 (total) / 1 (free) x internal 2.5" / 3.5" shared , 1 (total) / 1 (free) x external
- Slots
- 2 (total) / 2 (free) x PCIe 3.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x M.2 Card - 2230/2280 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode)
- 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 4 x USB 2.0 , 1 x VGA , 1 x DisplayPort , 1 x headphones/microphone , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, FIPS 140-2 Level 2, RoHS, WEEE, Common Criteria EAL4+
- Power supply
- Nominal Voltage
- Efficiency
- 90%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- HP Recovery Manager, HP Support Assistant, HP Hotkey Support, HP Spare Key, Windows Defender, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP Security Manager, HP Credential Manager, HP Client Catalogue (free download), HP Driver Packs, HP BIOS Config Utility, HP Device Access Manager, HP JumpStart, HP Workwise, HP Noise Cancellation, Native Miracast, HP Wireless Wakeup, HP PhoneWise, HP Sure Click, HP Manageability & Integration Kit Gen2, HP Client Security Suite Gen4, Power On Authentication
- 17 cm
- 27.4 cm
- 33.8 cm
- 5.47 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
