HP ProDesk 400 G5 DM Intel Core i5-9500T 8GB 256GB SSD Windows 10 Professional 64-bit
Quicklinx: FBRPWS00 Mfr#: 7EM44ET#ABU
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • Core i5
£502.26 ex VAT
£602.71 inc VAT
Designed to fit the modern workspace with a compact, stylish appearance, the ultra-small HP ProDesk 400 Desktop Mini is an affordable PC with reliability and performance for your growing business.
  • Powerful and configurable
    Power through your day with a solution you can flexibly configure with an 8th Gen Intel Core processor and options that include Intel Optane memory, SSD storage, and up to 32 GB of DDR4 memory.
  • Expansion that extends your investment
    Maximize the life of your PC as your business requirements change with a wide range of storage options such as the latest M.2 slots, traditional SATA drives, and configurable ports to connect up to three HP displays.
  • Place it where you need it
    Take your footprint down to near zero with a PC that attaches behind an HP EliteDisplay, or mount and secure it almost anywhere with HP accessories. Declutter your space with short cables and rear I/O ports that connect to a range of displays.
  • HP-exclusive security and manageability
    Help prevent data breaches and downtime with HP BIOSphere Gen4 and protect against web-based attacks with HP Sure Click. Easily manage devices through Microsoft System Center Configuration Manager with HP Manageability Integration Kit.
HP ProDesk 400 G5 - mini desktop - Core i5 9500T 2.2 GHz - 8 GB - 256 GB - UK
Personal computer - mini desktop
1 x Intel Core i5 (9th Gen) 9500T / 2.2 GHz (3.7 GHz) (6-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
1 x SSD 256 GB - PCI Express 3.0 - M.2 2280 - NVM Express (NVMe)
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
GigE
Keyboard
OS Provided
17.7 cm x 17.5 cm x 3.42 cm
1.25 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.7 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
SSD - M.2 2280
1 x 256 GB
Interface Type
PCI Express 3.0
NVM Express (NVMe)
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 1 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280/2230 (x4 mode)
2 x USB 2.0 , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is charging) , 2 x DisplayPort , 1 x headphones/microphone , 1 x headphones , 1 x LAN (Gigabit Ethernet)
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, WEEE, Common Criteria EAL4+, low halogen
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
88% (115VAC) / 89% (230VAC)
Operating System / Software
OS Provided
Software
HP Support Assistant, HP Hotkey Support, Windows Defender, HP Secure Erase, HP Drive Packs (free download), HP BIOS Config Utility, HP Setup Integrated OOBE, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP Manageability Integration Kit Gen3, HP BIOSphere Gen5, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense
ENERGY STAR Certified
17.7 cm
17.5 cm
3.42 cm
1.25 kg
Shipping Width
49.7 cm
Shipping Depth
12.8 cm
Shipping Height
22.3 cm
Shipping Weight
2.97 kg
5 °C
35 °C
5 - 90% (non-condensing)
HP ProDesk 400 G5 DM Intel Core i5-9500T 8GB 256GB SSD Windows 10 Professional 64-bit Bundle deal on HP ProDesk 400 G5 DM Intel Core i5-9500T 8GB 256GB SSD Windows 10 Professional 64-bit
£601.43
Storage Type: SSD
Processor Model: I5-9500T
Type: Personal computer
Case Style: Desktop slimline
Display: no
Optical Storage: None
Brand: HP
Price Range Ex VAT: 500 - 750
