Designed to fit the modern workspace with a compact, stylish appearance, the ultra-small HP ProDesk 400 Desktop Mini is an affordable PC with reliability and performance for your growing business.
Powerful and configurable
Power through your day with a solution you can flexibly configure with an 8th Gen Intel Core processor and options that include Intel Optane memory, SSD storage, and up to 32 GB of DDR4 memory. -
Expansion that extends your investment
Maximize the life of your PC as your business requirements change with a wide range of storage options such as the latest M.2 slots, traditional SATA drives, and configurable ports to connect up to three HP displays. -
Place it where you need it
Take your footprint down to near zero with a PC that attaches behind an HP EliteDisplay, or mount and secure it almost anywhere with HP accessories. Declutter your space with short cables and rear I/O ports that connect to a range of displays. -
HP-exclusive security and manageability
Help prevent data breaches and downtime with HP BIOSphere Gen4 and protect against web-based attacks with HP Sure Click. Easily manage devices through Microsoft System Center Configuration Manager with HP Manageability Integration Kit.
- HP ProDesk 400 G5 - mini desktop - Core i3 9100T 3.1 GHz - 8 GB - SSD 256 GB - UK
- Personal computer - mini desktop
- Localisation
- Processor
- Intel Core i3 (9th Gen) 9100T / 3.1 GHz (3.7 GHz) (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB (installed) / 64 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 256 GB - PCI Express 3.0 - M.2 2280 - NVM Express (NVMe)
- Optical Storage
- No optical drive
- Graphics Controller
- Intel UHD Graphics 630 Dynamic Video Memory Technology
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 17.7 cm x 17.5 cm x 3.42 cm
- 1.25 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Mini desktop
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel B360
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB / 64 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 1 (empty)
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - M.2 2280
- Capacity
- 1 x 256 GB
- Interface Type
- PCI Express 3.0
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 1 (free) x internal 2.5"
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2230/2280 (x4 mode)
- 2 x USB 2.0 , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is charging) , 2 x DisplayPort , 1 x headphones/microphone , 1 x headphones , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- RoHS, WEEE, Common Criteria EAL4+, low halogen
- Power adapter
- Nominal Voltage
- Power Provided
- 65 Watt
- Efficiency
- 88% (115VAC) / 89% (230VAC)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- Software
- HP Support Assistant, HP Hotkey Support, Windows Defender, HP Secure Erase, HP Drive Packs (free download), HP BIOS Config Utility, HP Setup Integrated OOBE, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP Manageability Integration Kit Gen3, HP BIOSphere Gen5, HP Privacy Settings, HP Cloud Recovery, HP Sure Sense
- ENERGY STAR Certified
- 17.7 cm
- 17.5 cm
- 3.42 cm
- 1.25 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 22.3 cm
- Shipping Weight
- 2.97 kg
- 5 °C
- 35 °C
- 5 - 90% (non-condensing)
