Designed to fit the modern workspace now and in the future, the small, reliable, and secure HP ProDesk 400 SFF is a powerful PC with performance, that's scalable to grow with the business.
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful HP ProDesk 400 SFF with built-in security, collaboration, and connectivity.
Super secure. Super protected
HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users.
Work without interruption
Keep productivity high and downtime low with HP BIOSphere Gen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
Speed up the basics of IT management
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
Power through your day with Windows 10 Pro and the powerful HP ProDesk 400 SFF with built-in security, collaboration, and connectivity. -
HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users. -
Keep productivity high and downtime low with HP BIOSphere Gen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks. -
The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager. -
Convenient, always-on, customized, free support
Enjoy always-on, included self-help support built right into your PC, for the life of your PC.
- HP ProDesk 400 G4 - SFF - Core i5 6500 3.2 GHz - 4 GB - HDD 500 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i5 (6th Gen) 6500 / 3.2 GHz (, up to 3.6 GHz, (Quad-Core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 500 GB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- Stereo
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 27 cm x 29.6 cm x 9.5 cm
- 4.6 kg
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker, solenoid hood lock
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.2 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel H270
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 2.5" / 3.5" shared
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
- 4 x USB 2.0 (two of them with wake functionality) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 82% at 100% Load (115 VAC), 82% at 20% Load (115 VAC), 85% at 50% Load (115 VAC)
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- 27 cm
- 29.6 cm
- 9.5 cm
- 4.6 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (1)
HP Care Pack Next Business Day HW Support Post Warranty Extended Service Agreement 1 Year On-Site | In Stock | £14.86 |
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
Other bundles (3)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
