HP ProDesk 400 G4 Intel Core i3 7100 8GB 256GB SSD
Quicklinx: CT9TWS00 Mfr#: 1JJ62ET#ABU
  • Core i3
Designed to fit the modern workspace, the small, reliable, and secure HP ProDesk 400 is a powerful PC with performance that's scalable to grow with the business.
Powerful options
Power through your day with high-performance 7th Gen Intel® Core™ i3/i5/i7processors unleashed optional Intel® Optane™ memory and SSDs, up to 32 GB of DDR4 memory, and discrete graphics.
Expansion that extends your investment
The full value of your investment comes with expansion that extends the life of your PC. The HP ProDesk 400 SFF has two bays and two half-height slots, and optional legacy ports.
Connection hub
With 8 total USB ports, two video outputs, and optional Bluetooth™ connectivity, the HP ProDesk 400 SFF becomes a hub for all your devices in the office.
Tested and ready
The reliable HP ProDesk 400 SFF experienced 120,000 hours of the HP Total Test Process and now has an optional dust filter to help extend the life of your PC by reducing airborne particulate intake in the most demanding work environments.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful HP ProDesk 400 SFF with built-in security, collaboration, and connectivity.
  • Super secure. Super protected
    HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users.
  • Work without interruption
    Keep productivity high and downtime low with HP BIOSphere Gen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
  • Convenient, always-on, customized, free support
    Enjoy always-on, included self-help support built right into your PC, for the life of your PC.
HP ProDesk 400 G4 - SFF - Core i3 7100 3.9 GHz - 8 GB - SSD 256 GB - UK
Personal computer - small form factor
Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Hyper-Threading Technology, Intel Smart Cache
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 256 GB - SATA 6Gb/s
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
1GbE
Keyboard
OS Provided
Windows 10 Pro 64-bit Edition
Software Included
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Velocity, HP Secure Erase, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP JumpStart, HP Noise Cancellation, HP BIOSphere Gen3, HP JetAdvantage, HP Manageability & Integration Kit (free download), HP Notifications
27 cm x 29.6 cm x 9.5 cm
4.6 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
3.9 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H270
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Localization & Layout
Mouse
Optical
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 1 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 2.5" / 3.5" shared
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
4 x USB 2.0 (two of them with wake functionality) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, Common Criteria EAL4+
Power supply
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
82% at 100% Load (115 VAC), 82% at 20% Load (115 VAC), 85% at 50% Load (115 VAC)
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
27 cm
29.6 cm
9.5 cm
4.6 kg
10 °C
35 °C
10 - 90% (non-condensing)
