HP ProDesk 400 G4 DM Core i5-8500T 8GB 1TB HDD Windows 10 Pro
Quicklinx: DQ8BWS00 Mfr#: 4DA02ET#ABU
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
Storage Type: HDD
  • Core i5
£424.73 ex VAT
£509.67 inc VAT
Designed to fit the modern workspace now and in the future, the small, reliable, and secure HP ProDesk 400 SFF is a powerful PC with performance, that's scalable to grow with the business.
  • Powerful and configurable
    Power through your day with a solution you can flexibly configure with an 8th Gen Intel Core processor and options that include Intel Optane memory, SSD storage, and up to 32 GB of DDR4 memory.
  • Expansion that extends your investment
    Maximize the life of your PC as your business requirements change with a wide range of storage options such as the latest M.2 slots, traditional SATA drives, and configurable ports to connect up to three HP displays.
  • Place it where you need it
    Take your footprint down to near zero with a PC that attaches behind an HP EliteDisplay, or mount and secure it almost anywhere with HP accessories. Declutter your space with short cables and rear I/O ports that connect to a range of displays.
  • HP-exclusive security and manageability
    Help prevent data breaches and downtime with HP BIOSphere Gen4 and protect against web-based attacks with HP Sure Click. Easily manage devices through Microsoft System Center Configuration Manager with HP Manageability Integration Kit.
HP ProDesk 400 G4 - mini desktop - Core i5 8500T 2.1 GHz - 8 GB - 1 TB - UK
Personal computer - mini desktop
1 x Intel Core i5 (8th Gen) 8500T / 2.1 GHz (3.5 GHz) (6-core)
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
9 MB
Cache Per Processor
9 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics 630
Audio Output
Stereo
GigE
Keyboard
OS Provided
17.7 cm x 17.5 cm x 3.42 cm
1.25 kg
TCO Certified
TCO Certified Desktops 5
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
6-core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel B360
Cache Memory
Installed Size
9 MB
Cache Per Processor
9 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280/2230 (x4 mode)
2 x USB 2.0 , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 2 x DisplayPort , 1 x headphones/microphone , Headphones , 1 x LAN (Gigabit Ethernet) , 1 x VGA
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
Common Criteria EAL4+, low halogen
Power adapter
Nominal Voltage
Power Provided
65 Watt
Efficiency
89%
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Environmental Standards
TCO Certified
17.7 cm
17.5 cm
3.42 cm
1.25 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP ProDesk 400 G4 DM Core i5-8500T 8GB 1TB HDD Windows 10 Pro Bundle deal on HP ProDesk 400 G4 DM Core i5-8500T 8GB 1TB HDD Windows 10 Pro
£607.89
saving £8.33
£523.90
Storage Type: HDD
Processor Model: I5-8500T
Type: Personal computer
Case Style: Desktop slimline
Display: not included
Optical Storage: None
Brand: HP
Price Range Ex VAT: 300 - 500
