Give your business the strong foundation it needs for growth with the affordable and reliable HP ProDesk 400 MT. Designed with essential security and manageability features, the HP ProDesk 400 helps keep your business growing.
Let Nothing Stand In Your Way
Help protect from today's security threats and maximize management and productivity features for business.
Communication Made Easy
Make conferencing from your PC as simple as the touch of a button with the HP conferencing keyboard.
Grow With Work Demands
Extend the life of your purchase using the tool-less chassis to easily upgrade memory, storage, and graphics to meet diverse and growing business needs.
Connect To More Capabilities
Multiple displays have shown to help increase productivity by 35% and the HP ProDesk 400 MT allows you to connect two HP Pro Displays right out-of-the-box.
Cloud-Based IT Management Made Simple
Manage data, security, and devices from a single cloud-based solution with HP Touchpoint Manager.
Let nothing stand in your way
Help protect from today's security threats and maximize management and productivity features for business. -
Communication made easy
Make conferencing from your PC as simple as the touch of a button with the HP conferencing keyboard. -
Grow with work demands
Extend the life of your purchase using the tool-less chassis to easily upgrade memory, storage, and graphics to meet diverse and growing business needs. -
Connect to more capabilities
Multiple displays have shown to help increase productivity by 35% and the HP ProDesk 400 MT allows you to connect two HP Pro Displays right out-of-the-box. -
Cloud-based IT management made simple
- HP ProDesk 400 G3 - SFF - Core i3 6100 3.7 GHz - 4 GB - SSD 128 GB - UK
- Personal computer - small form factor
- Localisation
- Processor
- Intel Core i3 (6th Gen) 6100 / 3.7 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s - 3D V-NAND technology
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics 530
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Home 64-bit Edition
- Software Included
- CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, CyberLink PowerDVD BD Edition, Windows Defender, HP Systems Software Manager (free download), HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, HP CIK for Microsoft SCCM (free download)
- 27 cm x 29.95 cm x 9.5 cm
- 4.43 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 32 GB (max)
- Technology
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered
- Configuration Features
- 1 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio, DTS SOUND+
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Value
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Mouse Name
- HP USB Mouse
- Interface
- USB
- Interface (Bus) Type
- PCI Express 1.1 x1
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Remote Management Protocol
- SNMP 2
- Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 2.5" / 3.5" shared
- Slots
- 1 (total) / 1 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin
- 4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- Security Slot Type
- Kensington security slot
- ACPI, RoHS, WEEE
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 85%
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Home 64-bit Edition English
- Software
Sustainability Information
- ENERGY STAR Certified
- 27 cm
- 29.95 cm
- 9.5 cm
- 4.43 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
