HP ProDesk 400 G3 DM Intel Core i5-7500T 4GB 500GB Windows 10 Pro 64-bit
Quicklinx: D6H4WS00 Mfr#: 1EX77ET#ABU
  • Core i5
Give your business the strong foundation it needs for growth with the affordable and reliable HP ProDesk 400 MT. Designed with essential security and manageability features, the HP ProDesk 400 helps keep your business growing.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful HP ProDesk 400 Desktop Mini with built-in security, collaboration, and connectivity.
  • Super secure. Super protected
    HP Client Security Suite Gen3 features HP Multi-Factor Authenticate, HP Device Access Manager, HP SpareKey, and HP Password Manager. These tools work to keep data out of reach and defend against theft, attacks, and unauthorized users.
  • Work without interruption
    Keep productivity high and downtime low with HP BIOSphereGen3 firmware-level automation. Your PCs have extra protection thanks to automatic updates and security checks.
  • Speed up the basics of IT management
    The HP Manageability Integration Kit helps speed up image creation and management of hardware, BIOS, and security through Microsoft System Center Configuration Manager.
  • Convenient, always-on, customized, free support
    Enjoy always-on, included self-help support built right into your PC, for the life of your PC.
  • Built-in durability
    Rest easy with a PC that goes the distance and is designed to pass HP Total Test Process.
HP ProDesk 400 G3 - mini desktop - Core i5 7500T 2.7 GHz - 4 GB - HDD 500 GB
Personal computer - mini desktop
Intel Core i5 (7th Gen) 7500T / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 630
Audio Output
Stereo
1GbE
OS Provided
Windows 10 Pro 64-bit Edition
17.7 cm x 17.47 cm x 3.42 cm
1.21 kg
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Mini desktop
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA1151 Socket
Chipset Type
Intel H270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
Memory Specification Compliance
PC4-19200
SO-DIMM 260-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse
Mouse
Mouse Name
HP USB Mouse
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode)
2 x USB 2.0 (wake functionality) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) (one of them is fast-charging) , 1 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x serial
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
ACPI
Power adapter
Power Provided
65 Watt
Efficiency
89% (115VAC), 89% (230VAC)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
17.7 cm
17.47 cm
3.42 cm
1.21 kg
10 °C
35 °C
10 - 90% (non-condensing)
