The HP ProDesk 400 SFF with a 44% reduction in size from the previous generation, takes up much less space without sacrificing the computing power and security needed for business computing.
Windows 8.1
Start up and switch applications with the quick and fluid Windows 8.1. -
Super secure. Super protected
HP Client Security suite helps you quickly and easily encrypt your hard drive, permanently delete unwanted or discarded data, restrict unauthorized access, and more. -
Rapid recovery
HP BIOS Protection's automated recovery restores a copy of the BIOS from a partition on the hard drive if crisis strikes. -
Help secure critical data
With TPM 1.2, your critical data has protection with hardware-based encryption keys. -
Perform at the speed of work
Enjoy the business ready performance of 4th generation Intel Core processors equipped with a powerful chipset, processor support, and robust memory. -
Impressive graphics
Immerse yourself in the rich graphic experience provided by Intel graphics on your HP ProDesk 400 SFF.
- HP ProDesk 400 G2.5 - SFF - Pentium G3260 3.3 GHz - 4 GB - HDD 1 TB - UK
- Personal computer - small form factor - administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, HP Drive Encryption, SecureBoot, Hybrid Boot, Master Record Security, Measured Boot, Pre-boot Authentication
- Localisation
- Processor
- Intel Pentium G3260 / 3.3 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - non-ECC - PC3L-12800
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD SuperMulti
- Graphics Controller
- Intel HD Graphics
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink YouCam BE, HP Secure Erase, Drive Encryption, HP Client Security Manager
- 27 cm x 31.785 cm x 9.5 cm
- 4.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - on-site
- Personal computer
- Product Form Factor
- Small form factor
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel H81
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- Effective Memory Speed
- 1333 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3L-12800
- Form Factor
- DIMM 240-pin
- Slots
- 2 (Total) / 1 (empty)
- Unbuffered, dual channel memory architecture
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- VGA, DisplayPort
- HDCP Compatible
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Standard Value Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Interface
- USB
- Ethernet Controller
- Realtek RTL8111HSH-CG
- Data Link Protocol
- Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
- Bays
- 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" / 3.5" shared , 1 (total) / 1 (free) x external
- Slots
- 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 , 1 (total) / 1 (free) x PCIe 2.0 x1
- 2 x USB 3.0 (2 in front) , 6 x USB 2.0 , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out , 1 x audio line-in , 1 x headphones (1 in front) , 1 x microphone (1 in front)
- Administrator password, power-on password, hard drive I/O control, serial port I/O control, USB port control, DriveLock, HP BIOS Protection, HP Drive Encryption, SecureBoot, Hybrid Boot, Master Record Security, Measured Boot, Pre-boot Authentication
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- ACPI, Common Criteria EAL4+
- Power supply
- Voltage Required
- Power Provided
- 180 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
- Efficiency
- 85%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
- Software
Sustainability Information
- ENERGY STAR Certified
- 27 cm
- 31.785 cm
- 9.5 cm
- 4.5 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
