HP ProBook x360 440 G1 Intel Core i5-8250U 8GB 256GB SSD 14" Windows 10 Professional 64-bit
Quicklinx: DQ7YWS00 Mfr#: 4LT43ET#ABU
Display Size: 14in
Processor Model: I5-8250U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
£693.29 ex VAT
£831.94 inc VAT
Take on the demands of your growing business with the ultra-slim HP ProBook x360 440. Get the power, security, and durability you need in a versatile 360° design that adapts to the way you work.
  • Security, durability, easy to service
    Help defend against malicious attacks with built-in security from HP BIOSphere Gen4, a firmware ecosystem that automates protection of the BIOS, plus get commercial-grade durability and easy serviceability.
  • Power to boost productivity
    Power through your day with a high-performance 8th Gen Intel Core processor, long battery life, and support for USB Type-C docking enabling data, video and power through one connection.
  • Adapts for the way you work
    The versatile ultra-slim HP ProBook x360 440 adapts throughout the day, with four use modes that enable you to create, present, and collaborate in a comfortable way.
HP ProBook x360 440 G1 - 14" - Core i5 8250U - 8 GB RAM - 256 GB SSD - UK
Notebook - flip design
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD NVMe
Optical Drive
No optical drive
Display
14" WLED touchscreen 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
ClickPad
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 13 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip
33 cm x 23.2 cm x 1.99 cm
1.72 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe)
Display
14" - IPS
LCD Backlight Technology
WLED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Slim Design, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, 62.5% sRGB colour gamut
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers, dual array microphone
Input
Keyboard, ClickPad
Keyboard Layout
Numeric Keypad
Spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Miracast, dual stream (2x2)
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
Run Time
Up to 13 hours
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , USB 3.0 (charging) , USB 3.0 , HDMI , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDXC Card)
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Velocity, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Workwise, HP Noise Cancellation, HP System Software Manager, HP JetAdvantage, HP PhoneWise, HP Manageability Integration Kit Gen2, Ivanti Management Suite
Security
Automatic DriveLock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security, BIOS Update via Network
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, ICCP
Localization
1.72 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: HP
Price Range Ex VAT: 500 - 750
