HP ProBook 655 AMD A8-4500M 4GB 500GB 15.6" Windows 7 Professional 64-bit
Quicklinx: 99SQWS00 Mfr#: F1N83EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Take on tasks in the office or on the road with the durable HP ProBook 645 and HP ProBook 655. These ProBooks are thin, light and a great value. Enjoy enhanced productivity and do more – faster and better – to meet the most demanding workloads.
  • Thinner, tougher taskmaster
    Get the technology you trust from HP, with cutting-edge style that looks and feels the way you want.Join forces with the latest generation technology and legacy features your business demands on a new thinner HP ProBook for in the office or on the go.Protect existing IT investments with support for existing legacy features such as an optical drive, optional serial ports, VGA and RJ45 connectors.Enjoy a desktop experience on your ProBook with various docking options including HP 120W Advanced Docking Station and HP 90W Docking Station.
  • Design your ideal ProBook
    Take advantage of the wide range of features and configurable options on the new HP ProBook 600 Series.Configure a ProBook made for your business thanks to flexible architecture configurations including the latest AMD Richland APUs.Experience great visual performance with full-HD display options, AMD Radeon HD 8000G Series graphics.Bridge distances on the HP ProBook 600 series, with Microsoft Lync, premium audio/video and full-HD display.Stay in touch from the office or on the road with powerful connectivity options including 4G WWAN, HP Wireless Hotspot and Bluetooth 4.0.
  • Convenient Control
    Protect data, devices and identities with HP Client Security and HP BIOS Protection.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.Enjoy easy and simple integration into your IT environment with HP Client Management Solutions such as optional LANDesk technology.Maintain a productive system environment with stable and consistent images, managed lifecycle transitions and Global Series support you can rely on.
HP ProBook 655 G1 Notebook - 15.6" - AMD A8 - 4500M - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8 Pro) + Windows 8 Pro Licence
AMD A8 4500M / 1.9 GHz, up to 2.8 GHz / 4 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight HD anti-glare 1366 x 768 / HD
Graphics
AMD Radeon HD 7640G
Input Device
Pointing stick
Numeric Keypad
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
6-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
37.8 cm x 25.7 cm x 2.9 cm
2.32 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro) + Windows 8 Pro Licence
Processor / Chipset
CPU
Max Turbo Speed
2.8 GHz
Number of Cores
Quad-Core
Cache
4 MB
64-bit Computing
Chipset
AMD A76M FCH
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM removable - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
HD anti-glare
Audio & Video
Graphics Processor
AMD Radeon HD 7640G
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
High Definition Audio, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Numeric Keypad
Spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.3az
6-cell Lithium Ion
55 Wh
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
Expansion Bays
1 x Upgrade Bay
4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock , Serial
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, CyberLink YouCam BE, HP Client Security, HP PageLift
Case Material
ABS plastic
Dockable
Security
Power-on password, HP 3D DriveGuard, HP SpareKey, HP File Sanitizer, HP BIOS Protection, USB 3.0 port power off USB charging, SecureBoot
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
Localization
2.32 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
