Take on tasks in the office or on the road with a durable HP ProBook 640 and HP ProBook 650. These ProBooks are thin, light and packed with productivity features to make work faster and easier. Plus, reliable security solutions keep your data out of the wrong hands.
Thinner, tougher taskmaster
Get the technology you trust from HP, with cutting-edge style that looks and feels the way you want.Join forces with the latest generation technology and legacy features your business demands on a new thinner HP ProBook for in the office or on the go.Protect existing IT investments with support for existing legacy features such as an optical drive, optional serial ports, VGA and RJ45 connectors.Enjoy a desktop experience on your ProBook with various docking options including HP 120W Advanced Docking Station and HP 90W Docking Station. -
Design your ideal ProBook
Take advantage of the wide range of features and configurable options on the new HP ProBook 600 Series.Configure a ProBook made for your business thanks to flexible architecture configurations including the latest Intel 4th generation processors.Experience great visual performance with full-HD display options, AMD 1GDDR5 discrete graphics and native DisplayPort 1.2.Bridge distances on the HP ProBook 600 series, with Microsoft Lync, premium audio/video and full-HD display.Stay in touch from the office or on the road with powerful connectivity options including 4G WWAN, HP Wireless Hotspot and Bluetooth 4.0. -
Convenient Control
Protect data, devices and identities with HP Client Security and HP BIOS Protection.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.Enjoy easy and simple integration into your IT environment with HP Client Management Solutions such as optional LANDesk and Intel vPro technology.Maintain a productive system environment with stable and consistent images, managed lifecycle transitions and Global Series support you can rely on.
- HP ProBook 650 G1 Notebook - 15.6" - Intel Core i5 - 4300M - vPro - 4 GB RAM - 500 GB HDD
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (4th Gen) - 4300M / 2.6 GHz, up to 3.3 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight HD SVA eDP anti-glare 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4600
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 6-cell - up to 11.12 hours
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 37.8 cm x 25.7 cm x 2.53 cm
- 2.32 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Recommended Use
- Small business, corporate business
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4300M / 2.6 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Dual-Core
- Cache
- L3 - 3 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Intel Turbo Boost Technology
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Sound
- Stereo speakers, microphone
- DTS SOUND+
Input
- Keyboard, touchpad
- Spill-resistant, multi-touch touchpad
Communications
- Wireless
- Bluetooth Class
- Class 2
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 6-cell Lithium Ion
- Capacity
- 55 Wh
- Run Time
- Up to 11.12 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 18.5 V
Connections & Expansion
- 5 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock , Serial
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, CyberLink YouCam BE, Drive Encryption for HP ProtectTools, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP Trust Circles, Box.net 50GB storage
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- Power-on password, HP Disk Sanitizer, HP 3D DriveGuard, Enhanced Pre-Boot Security, HP SpareKey, HP BIOS Protection, Automatic DriveLock, HP SureStart, 1 USB 3.0 (powered), SecureBoot
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, FCC, RoHS, WEEE, A-Tick, ICES, UkrSEPRO, KC, CIT
- Localization
- 2.32 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance
- 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
- Vibration Tolerance
- 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
