Protect your existing IT investments with the cost-effective HP ProBook 645, that integrates with your legacy devices and is equipped with the security and productivity features. Ideal for professionals in corporate settings or small to medium businesses, wanting an affordable combination of innovation, essential security and multimedia capabilities.
Utilize your existing IT infrastructure
Legacy features on the HP ProBook 645 like an optional optical drive, a standard VGA port, and an RJ-45 connection help you get the most out of your existing IT investments.
Create a full-featured experience
6th or 7th generation AMD APUs, robust DDR4 memory, and professional-grade peripheral devices like the HP UltraSlim dock create a full-featured budget-friendly experience.
Strong security easily managed
Help protect and manage your PCs with business-class security and manageability solutions. TPM, HP BIOSphere Gen3 and HP Client Security Gen3 help guard data while global configuration across 180 countries simplifies management.
Business-ready collaboration
Impressive collaboration tools like Skype for Business, bi-directional HP Noise Cancellation Software, HP Audio Boost, and a 720p webcam make you ready for collaboration on the go.
Let nothing stand in your way
Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 645. -
Cost effective configurations
Configure the right ProBook for each user's needs with a wide range of features and configurable options. -
Charge faster and go longer
Replace batteries less often and quickly recharge your HP ProBook 645 with an HP fast charging battery. You'll get up to 90% battery life in just 90 minutes of charging. -
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Cancellation software. -
Give your speakers a boost
HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality. -
Work without interruption
Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen3 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks.
- HP ProBook 645 G3 Notebook - 14" - AMD A10 - PRO-8730B - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD A10 PRO-8730B / 2.4 GHz, up to 3.3 GHz / 2 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - HP Z Turbo Drive G2, NVMe, TLC
- Optical Drive
- DVD-Writer
- Display
- 14" WLED 1920 x 1080 / Full HD
- Graphics
- AMD Radeon R5
- Input Device
- Pointing stick
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell - up to 8 hours
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 34 cm x 23.7 cm x 2.7 cm
- 1.95 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD PCIe - HP Z Turbo Drive G2, NVM Express (NVMe), triple-level cell (TLC)
- Optical Drive
- DVD-Writer
Display
- 14"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 300 cd/m²
- Colour Gamut
- 60%
- Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- AMD Radeon R5
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
Input
- Keyboard, touchpad, pointing stick
- Keyboard Layout
- UK
- Spill-resistant, gesture function
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Realtek RTL8111HSH
- IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- USB-C , USB 3.0 , USB 3.0 (charging) , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- CyberLink Power2Go, Skype, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP 3D DriveGuard 6, HP Mobile Connect Pro, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP MAC Address Manager, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3, HP JetAdvantage, HP Driver Packs (free download)
- Dockable
- Security
- HP 3D DriveGuard, Automatic DriveLock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS, WEEE, Common Criteria EAL4+
- Localization
- 1.95 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
