HP ProBook 645 G2 A10-8700B
Quicklinx: CFLGWS00 Mfr#: V1B39EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Equip your workforce with HP's most configurable and cost effective notebook PC. Confidently deploy the HP ProBook 645 which combines support for legacy features that provide long-term stability with modern security for today's business.
Easily fits existing IT infrastructure
Help get the most out of existing IT investments with legacy feature support available on the HP ProBook 645 like an optional optical drive, a standard VGA port, and an RJ-45 connection.
Cost effective configurations
The HP ProBook 645 is equipped with powerful AMD APUs and offers a wide range of options allowing businesses to configure the right ProBook for each user’s needs.
Professional-grade
Create a full featured experience with powerful processors, robust DDR3 memory, and professional-grade peripheral devices like HP Pro Displays and an HP Ultraslim dock.
Executive-class collaboration
Interact naturally with your PC using an optional FHD Touch screen and Cortana on Windows 10 Pro. Enjoy impressive collaboration tools like Skype for Business, HP Noise Reduction Software, and a 720p webcam for collaboration on the go.
Key Features
Let nothing stand in your way
Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 645.
Customized protection
HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
Give your speakers a boost
Help make good speakers sound great with the HP Clear Sound Amp.
Tested to go the distance
Stand up to the workload with a ProBook that passed MIL-STD 810G testing.
Protect against minor spills
Help protect your ProBook with a spill-resistant HP Premium Keyboard with backlit options available.
Consistent global deployments
Get the same HP configuration across the globe, available in more than 180 countries where HP conducts business.
Proactively monitor and troubleshoot
Avoid surprises by tracking device health and security policy enforcement. With the HP Touchpoint Manager app, IT can quickly address risks to keep devices functional, and employees productive.
HP ProBook 645 G2 - 14" - A10 PRO-8700B - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
AMD A10 PRO-8700B / 1.8 GHz (3.2 GHz) / 2 MB Cache /
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon R6
Input Device
Pointing stick
Keyboard
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
34 cm x 23.7 cm x 2.7 cm
1.95 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Slim Design, Full HD standard-viewing angle (SVA) anti-glare
Audio & Video
Graphics Processor
AMD Radeon R6
Camera
Yes - 720p
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
High Definition Audio, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSH
IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
AC Adapter
Output
45 Watt
Connections & Expansion
USB-C , 2 x USB 3.0 , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, CyberLink YouCam BE, HP Spare Key, Password Manager, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, Drive Encryption, HP GPS and Location, HP Credential Manager, HP 3D DriveGuard
Case Material
Polycarbonate ABS
Dockable
Security
HP 3D DriveGuard, HP SpareKey, HP BIOS Protection, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
1.95 kg
ENERGY STAR Certified
