HP ProBook 645 A108730B 4GB 500GB 14" Windows 10 Pro
Quicklinx: CRV2WS00 Mfr#: Z2W15EA#ABU
Display Size: 14in
Processor Model: A10 PRO-8730B, A10 PRO-8730B
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • IEEE 802.11n
£700.91 ex VAT
£841.09 inc VAT
Protect your existing IT investments with the cost-effective HP ProBook 645, that integrates with your legacy devices and is equipped with the security and productivity features. Ideal for professionals in corporate settings or small to medium businesses, wanting an affordable combination of innovation, essential security and multimedia capabilities.
Utilize your existing IT infrastructure
Legacy features on the HP ProBook 645 like an optional optical drive, a standard VGA port, and an RJ-45 connection help you get the most out of your existing IT investments.
Create a full-featured experience
6th or 7th generation AMD APUs, robust DDR4 memory, and professional-grade peripheral devices like the HP UltraSlim dock create a full-featured budget-friendly experience.
Strong security easily managed
Help protect and manage your PCs with business-class security and manageability solutions. TPM, HP BIOSphere Gen3 and HP Client Security Gen3 help guard data while global configuration across 180 countries simplifies management.
Business-ready collaboration
Impressive collaboration tools like Skype for Business6, bi-directional HP Noise Cancellation Software, HP Audio Boost, and a 720p webcam make you ready for collaboration on the go.
  • Utilize your existing IT infrastructure
    Legacy features on the HP ProBook 645, like a standard VGA port and an RJ-45 connection, help you get the optimal out of your existing IT investments.
  • Create a full-featured experience
    Robust memory and professional-grade peripheral devices create a full-featured budget-friendly experience.
  • Strong security, easily managed
  • Business-ready collaboration
    Impressive collaboration tools, like HP Audio Boost and a 720p webcam, make you ready for collaboration on the go.
HP ProBook 645 G3 - 14" - A10 PRO-8730B - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD A10 PRO-8730B / 2.4 GHz (3.3 GHz) / 2 MB Cache /
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
14" WLED 1920 x 1080 / Full HD
Graphics
AMD Radeon R5
Input Device
Pointing stick
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 8 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
34 cm x 23.7 cm x 2.7 cm
1.95 kg
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
1866 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
14"
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
300 cd/m²
60% colour gamut, Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
AMD Radeon R5
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Input
Keyboard, touchpad, pointing stick
Keyboard Layout
Spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSH
IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
Run Time
Up to 8 hours
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB-C , USB 3.0 , USB 3.0 (charging) , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
CyberLink Power2Go, Skype, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP 3D DriveGuard 6, HP Mobile Connect Pro, HP JumpStart, HP Sure Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP MAC Address Manager, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3, HP JetAdvantage
Dockable
Security
HP 3D DriveGuard, Automatic DriveLock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS, WEEE, Common Criteria EAL4+
Localization
1.95 kg
ENERGY STAR Certified
Software applications
HP ProBook 645 A108730B 4GB 500GB 14 Bundle deal on HP ProBook 645 A108730B 4GB 500GB 14" Windows 10 Pro
£800.08
Display Size: 14in
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Graphics: AMD Radeon R5
Hard Drive Type: HDD
Brand: HP
Price Range Ex VAT: 500 - 750
