HP ProBook 640 G4 Core i5-8250U 4GB 500GB HDD 14" Windows 10 Pro
Quicklinx: DQ80WS00 Mfr#: 3UN82ET#ABU
  • Core i5
  • IEEE 802.11n
The all new modern ultra-slim design of the HP ProBook 640 delivers enterprise-grade performance, security, manageability, and flexible configuration options.
  • Let nothing stand in your way
    Power through your day with Windows 10 Pro and the powerful security, collaboration and connectivity features from HP.
  • Powering your creativity
    Take on demanding graphics and video tasks using high resolution 4k displays with optional AMD Radeon RX540 Discrete Graphics.
  • Preserve your privacy
    Never wonder if someone is watching you with the added peace-of-mind that comes from the integrated HP Privacy Camera, with a physical shutter to protect from malicious surveillance.
  • Firmware level protection
    Protect the firmware that antivirus can't reach! The hardware-enforced self-healing protection offered by HP Sure Start Gen4 automatically recovers the BIOS from malware, rootkits, or corruption.
  • Protect identities with HP Multi-Factor Authenticate Gen2
    Fortify your security with up to three authentication factors including passwords and optional fingerprint recognition.
HP ProBook 640 G4 Notebook - 14" - Intel Core i5 - 8250U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) - 8250U / 1.6 GHz, up to 3.4 GHz / 6 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Hood sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Natural silver
34 cm x 24 cm x 2.09 cm
1.73 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (8th Gen) 8250U / 1.6 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Colour Gamut
45%
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Advanced
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Spill-resistant, multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Dual stream (2x2)
3-cell lithium polymer
48 Wh
AC Adapter
Input
Connections & Expansion
Interfaces Details
USB-C 3.1 (charging) , 2 x USB 3.1 , USB 3.1 (charging) , HDMI , LAN , VGA , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD)
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP Credential Manager, HP BIOS Config Utility, HP Device Access Manager, HP 3D DriveGuard, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, Native Miracast, HP JetAdvantage, HP PhoneWise, HP Sure Click, HP BIOSphere Gen4, Ivanti Management Suite (subscription required), HP Client Security Suite Gen4, HP Host Based MAC Address Manager, HP Manageability & Integration Kit Gen2 (free download)
Natural silver
Integrated Options
Hood sensor
Dockable
Security
DriveLock, BIOS Absolute Persistence, HP Automatic Drive Lock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, Secure Erase, HP Sure Start Gen 4, HP Wireless Wakeup, BIOS Update via Network
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, ICCP
Localization
1.73 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Essential Accessories (8)
Get more from your purchase from one of our essential accessories
DQ80 HP 90W Smart AC Adapter In Stock £22.69
DQ80 HP 65W Smart AC Adapter In Stock £18.54
DQ80 HP Power Connector Adaptor DC Jack 7.4mm (F) To DC Jack In Stock £13.44
DQ80 HP Dual Head Keyed Cable Lock In Stock £43.00
DQ80 HP USB-C mini Dock - Docking Station - USB-C - VGA, HDMI - GigE In Stock £33.61
DQ80 HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt In Stock £147.06
DQ80 HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt In Stock £206.71
DQ80 HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook In Stock £41.06
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
DQ80 HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site In Stock £129.73
Other bundles (11)
DQ80 HPE DisplayPort To VGA Adapter In Stock £13.72
DQ80 HPE DisplayPort to HDMI Adapter In Stock £13.44
DQ80 HPE HP DisplayPort to DVI Adapter In Stock £17.23
DQ80 HP USB-C To VGA Adapter In Stock £22.68
DQ80 HP USB Travel Mouse In Stock £10.14
DQ80 HP X4000b Bluetooth Mouse In Stock £28.71
DQ80 HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor In Stock £2,821.06
DQ80 HP Premium Wireless Mouse In Stock £38.00
DQ80 HP USB-C to DisplayPort Adapter In Stock £23.53
DQ80 HP USB-C to HDMI 2.0 Adapter In Stock £47.06
DQ80 HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor In Stock £144.44
