HP ProBook 640 G4 Core i5-8250U 4GB 500GB HDD 14" Windows 10 Pro
Quicklinx: DQ80WS00 Mfr#: 3UN82ET#ABU
Display Size: 14in
Processor Model: I5-8250U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • Core i5
  • IEEE 802.11n
£787.21 ex VAT
£944.65 inc VAT
The all new modern ultra-slim design of the HP ProBook 640 delivers enterprise-grade performance, security, manageability, and flexible configuration options.
  • Updated ultra-slim design
    The precision-crafted ultra-slim chassis in a modern natural silver finish is designed to pass MIL-STD 810G testing and supports several HP docking options for gradual transitions to modern docking solutions.
  • High performance
    Help speed up demanding business applications with an optional 8th Gen quad-core Intel Core processor and discrete graphics.
  • Built on a secure foundation
    Protect your PC against the evolving malware threats of the future, with self-healing, hardware-enforced, and manageable security solutions from HP. From the BIOS to the browser HP Sure Start Gen4 and HP Sure Click help secure your PC.
HP ProBook 640 G4 - 14" - Core i5 8250U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) / 6 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
No optical drive
Display
14" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
ClickPad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Hood sensor
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
Natural silver
34 cm x 24 cm x 2.09 cm
1.73 kg
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.4 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Display
14" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
45% colour gamut, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
Keyboard Name
HP Advanced
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, dual array microphone
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Spill-resistant, multi-touch clickpad, gesture function
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Dual stream (2x2)
3-cell lithium polymer
48 Wh
AC Adapter
Input
Connections & Expansion
USB-C 3.1 (charging) , 2 x USB 3.1 , USB 3.1 (charging) , HDMI , LAN , VGA , Headphone/microphone combo jack , Dock
Memory Card Reader
Yes (microSD)
Software
Software Included
HP Recovery Manager, HP Support Assistant, HP ePrint, HP Hotkey Support, HP Spare Key, Password Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Security Manager, HP Drive Packs (free download), HP Client Catalog, HP Credential Manager, HP BIOS Config Utility, HP Device Access Manager, HP 3D DriveGuard, HP JumpStart, HP Noise Cancellation, HP System Software Manager, HP LAN-WLAN Protection, Native Miracast, HP JetAdvantage, HP PhoneWise, HP Sure Click, HP BIOSphere Gen4, Ivanti Management Suite (subscription required), HP Client Security Suite Gen4, HP Host Based MAC Address Manager, HP Manageability & Integration Kit Gen2 (free download)
Natural silver
Integrated Options
Hood sensor
Dockable
Security
DriveLock, BIOS Absolute Persistence, HP Automatic Drive Lock, Power On Authentication, HP Fast Charge, Pre-boot Authentication, Master Boot Record Security, Secure Erase, HP Sure Start Gen 4, HP Wireless Wakeup, BIOS Update via Network
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT, ICCP
Localization
1.73 kg
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: HDD
Type: Laptop
Brand: HP
Price Range Ex VAT: 750 - 1000
