HP ProBook 640 G1 Intel Core i5-4310 4GB 500GB 14" Windows 7 Professional 64-bit
Quicklinx: BHPNWS00 Mfr#: J6J45AW#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Take on tasks in the office or on the road with a durable HP ProBook 640 and HP ProBook 650. These ProBooks are thin, light and packed with productivity features to make work faster and easier. Plus, reliable security solutions keep your data out of the wrong hands.
  • Thinner, tougher taskmaster
    Get the technology you trust from HP, with cutting-edge style that looks and feels the way you want. Join forces with the latest generation technology and legacy features your business demands on a thinner HP ProBook for in the office or on the go.
  • Design your ideal ProBook
    Take advantage of the wide range of features and configurable options on the HP ProBook 600 series. Bridge distances on the HP ProBook 600 series, it is optimized for communication with Microsoft Lync, premium audio/video and HD display.
  • Convenient control
    Protect data, devices and identities with HP client security and use HP trust circles to make sure only assigned contacts can access critical files. Keep sensitive information in safe hands. HP trust circles protect your data by ensuring that only approved contacts can access critical files. Stay up and running. HP BIOS protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.
HP ProBook 640 G1 Notebook - 14" - Intel Core i5 - 4310M - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Intel Core i5 (4th Gen) - 4310M / 2.7 GHz, up to 3.4 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4600
Keyboard
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
6-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
34 cm x 23.7 cm x 2.9 cm
2 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - carry-in , Limited warranty - battery - 1 year
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Intel Core i5 (4th Gen) 4310M / 2.7 GHz
Max Turbo Speed
3.4 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Chipset
Intel QM87
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3L-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
14" - TN
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
DTS SOUND+
Input
Keyboard, touchpad
Keyboard Layout
Spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Remote Management Protocol
ASF 2.0
Wake-on-LAN (WOL)
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
6-cell Lithium Ion
55 Wh
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, Absolute Data Protect, HP Spare Key, Password Manager, HP Client Security, HP Mobile Connect, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP Trust Circles, Drive Encryption, HP Credential Manager
Case Material
Polycarbonate ABS
Dockable
Security
HP Disk Sanitizer, HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP SpareKey, HP File Sanitizer, HP BIOS Protection, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
Localization
2 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
