Take on tasks in the office or on the road with a durable HP ProBook 640 and HP ProBook 650. These ProBooks are thin, light and packed with productivity features to make work faster and easier. Plus, reliable security solutions keep your data out of the wrong hands.
Thinner, tougher taskmaster
Get the technology you trust from HP, with cutting-edge style that looks and feels the way you want. Join forces with the latest generation technology and legacy features your business demands on a thinner HP ProBook for in the office or on the go. -
Design your ideal ProBook
Take advantage of the wide range of features and configurable options on the HP ProBook 600 series. Bridge distances on the HP ProBook 600 series, it is optimized for communication with Microsoft Lync, premium audio/video and HD display. -
Convenient control
Protect data, devices and identities with HP client security and use HP trust circles to make sure only assigned contacts can access critical files. Keep sensitive information in safe hands. HP trust circles protect your data by ensuring that only approved contacts can access critical files. Stay up and running. HP BIOS protection offers enhanced protection against virus attacks to the BIOS and other security threats, and is designed to help prevent data loss and reduce downtime.
- HP ProBook 640 G1 Notebook - 14" - Intel Core i5 - 4310M - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
- Processor
- Intel Core i5 (4th Gen) - 4310M / 2.7 GHz, up to 3.4 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 4600
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
- Battery
- 6-cell
- Dockable
- Security
- Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
- 34 cm x 23.7 cm x 2.9 cm
- 2 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year - carry-in , Limited warranty - battery - 1 year
- Product Type
- Notebook
- Operating System
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
- CPU
- Intel Core i5 (4th Gen) 4310M / 2.7 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Chipset
- Intel QM87
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz / PC3L-12800
- Rated Speed
- 1600 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 3Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - 1280 x 720
- Sound
- Stereo speakers, stereo microphone
- Codec
- IDT 92HD91
- DTS SOUND+
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Spill-resistant, touchpad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM
- Remote Management Protocol
- ASF 2.0
- Wake-on-LAN (WOL)
- IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
- Technology
- 6-cell Lithium Ion
- Capacity
- 55 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 18.5 V
Connections & Expansion
- 4 x USB 3.0 , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP ePrint, Absolute Data Protect, HP Spare Key, Password Manager, HP Client Security, HP Mobile Connect, Device Access Manager with Just In Time Authentication, HP PageLift, HP Secure Erase, HP Trust Circles, Drive Encryption, HP Credential Manager
- Case Material
- Polycarbonate ABS
- Dockable
- Security
- HP Disk Sanitizer, HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP SpareKey, HP File Sanitizer, HP BIOS Protection, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
- Localization
- 2 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
