HP ProBook 470 G3 Intel Core i5-6200U 4GB 1TB Windows 7
Quicklinx: BXY0WS00 Mfr#: P5R19EA#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Built for productivity, the HP ProBook 470 delivers the performance and security features essential for today's workforce. The attractive and tough design provides professionals a flexible platform to stay productive in or out of the office.
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 470.
  • Tested to go the distance
    Gain fast, reliable wireless with built-in Wi-Fi and Bluetooth wireless technology.
  • Help secure critical data
    With TPM your critical data has protection with hardware-based encryption keys.
  • Protect against minor spills
    Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
  • Customized protection
    HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
HP ProBook 470 G3 Notebook - 17.3" - Intel Core i5 - 6200U - 4 GB RAM - 1 TB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
1 TB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight 1600 x 900 / HD+
Graphics
AMD Radeon R7 M340 / Intel HD Graphics 520
Video Memory
DDR3 SDRAM
Keyboard
Numeric Keypad
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
41.68 cm x 29.05 cm x 2.6 cm
2.61 kg
Environmental Standards
- ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6200U / 2.3 GHz
Max Turbo Speed
2.8 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Enhanced SpeedStep technology, Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM - tray
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1600 x 900 (HD+)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
HD+ standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
DDR3 SDRAM
Camera
Yes - 1280 x 720
Sound
Stereo speakers, two microphones
High Definition Audio, DTS Studio Sound
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 3165 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
Miracast, Wake-on-LAN (WOL)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
4-cell Lithium Ion
44 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB 3.0 , 2 x USB 2.0 , HDMI , Headphone/microphone combo jack , LAN , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Drivers & Utilities, CyberLink Power2Go, HP Recovery Disc Creator, Skype, LANDesk Management Suite, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), Absolute Persistence, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Caller Dashboard
Security
HP 3D DriveGuard, HP BIOS Protection, Automatic DriveLock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, HP Basic Messenger Carrying Case
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
Localization
2.61 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
