HP ProBook 455 G3 AMD A10-8700P 4GB 500GB 15.6" Windows 7 Professional
Quicklinx: C09PWS00 Mfr#: P4P65EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Protect your data and investment with the ProBook designed to deliver impressive performance and reliability. Take on your workday with the budget friendly HP ProBook 455.
Progressive style
Work confidently on the 39,6 cm (15.6") diagonal HP ProBook 455 with an aluminum reinforced keyboard deck and 120,000 hours of HP Testing and a new gravity black LCD cover design.
Affordable performance
Enjoy the robust performance of cost effective and energy-efficient AMD A-Series APUs.
Protect your work
The HP BIOSphere and embedded TPM help protect your PC from BIOS level attacks from viruses and malware.
Immersive experience
Enjoy the rich user experience of the HP ProBook 455 with long battery life and features designed to create a stunning visual and audio experience with options like discrete graphics and DTS Studio Sound.™
Key Features
Let nothing stand in your way
Be productive in any situation. Experience the new features of Windows 10 on the thin, light, HP ProBook 455.
Tested to go the distance
Stand up to the workload with a ProBook that passed MIL-STD 810G testing.
Help secure critical data
With TPM your critical data has protection with hardware-based encryption keys.
Protect against minor spills
Help protect your ProBook from minor spills with an optional backlit spill-resistant HP Premium Keyboard.
Proactively monitor and troubleshoot
Avoid surprises by tracking device health and security policy enforcement. With the HP Touchpoint Manager app, IT can quickly address risks to keep devices functional, and employees productive.
Customized protection
HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
Storage options
Optimize your storage with latest high-performing storage options from HP.
  • Let nothing stand in your way
  • Tested to go the distance
  • Help secure critical data
  • Protect against minor spills
  • Customized protection
HP ProBook 455 G3 Notebook - 15.6" - AMD A10 - 8700P - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro) + Windows 10 Pro Licence - English
AMD A10 8700P / 1.8 GHz, up to 3.2 GHz / 2 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon R6
Keyboard
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
4-cell
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
37.8 cm x 26.43 cm x 2.48 cm
2.26 kg
Environmental Standards
- EPEAT Climate+
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro) + Windows 10 Pro Licence - English
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
Quad-Core
Cache
L2 - 2 MB
64-bit Computing
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
HD anti-glare
Audio & Video
Graphics Processor
AMD Radeon R6
Camera
Yes - 720p
Sound
Stereo speakers, stereo microphone
Codec
Realtek ALC3227-CG
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant
Communications
Wireless
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED, IEEE 802.3az
4-cell Lithium Ion
44 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
2 x USB 3.0 , 2 x USB 2.0 , HDMI , VGA , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
CyberLink Power2Go, HP Recovery Disc Creator, Skype, LANDesk Management Suite, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), Absolute Persistence, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Caller Dashboard
Case Material
Aluminum
Security
Security lock slot (cable lock sold separately), HP Disk Sanitizer, HP 3D DriveGuard, HP SpareKey, HP File Sanitizer, HP BIOS Protection, Automatic DriveLock, SecureBoot, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 2.0 charging port, Hardware Root of Trust, Pre-boot Authentication
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
Localization
2.26 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
