HP ProBook 455 AMD A10-5750M 6GB 750GB 15.6" Windows 8 Professional 64-bit
Quicklinx: 9SBJWS00 Mfr#: F7Y09EA#ABU
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
Meet the demands of your work. Work smarter -and look good doing it -with an HP ProBook built to perform wherever business takes you. Count on a durable design inside and out, with integrated security and a spill-resistant keyboard. Plus, there's less bulk to bring with you, thanks to thin, stylish construction.
  • Built to perform
    Style you can see and feel. Get the technology you trust from HP with cutting-edge style that looks and feels the way you want.The power and performance of the HP ProBook is matched by the solid design and elegant finishes.Super speed. Now data is faster than ever. With USB 3.0, you'll get faster transfer speeds and increased bandwidth.Make the most of virtual conferencing. DTS Sound+ and an HD webcam bring work to life through rich sound and video.
  • Protect your work
    Stay one-step ahead of hacks and attacks. Built-in security safeguards your HP ProBook against viruses, detects possible corruption, and alerts you to unauthorized changes.HP Client Security software suite helps you encrypt your hard drive, permanently delete unwanted or discarded data, restrict unauthorized access, and more.Stay up and running. HP BIOS Protection offers enhanced protection against virus attacks and other security threats, and is designed to help prevent data loss and reduce downtime.No more remembering passwords. HP Password Manager lets you quickly log in to various online accounts. Now your passwords can be longer and more secure.
  • Tough on the job
    HP ProBooks undergo challenging tests so you don't have to. During the HP Total Test Process, PCs experience 115,000 hours of performance trials to ensure they can withstand rigorous work environments.Bumps happen. HP 3D DriveGuard helps protect your data when you're on the go by sensing sudden movement and protecting the hard drive.Tackle your workload with technology that's built strong, from the core up. This HP ProBook is made with glass fiber for lightness and durability.Help protect sensitive electronics and key components from minor spills with a thin layer of Mylar film in the spill-resistant keyboard.
  • It's all about connections
    With HP Wireless Hotspot, easily share your internet connection, helping colleagues to get online fast and improve productivity.Don't let the office tie you down. Work in more places with optional high-speed wireless connectivity, including 4G LTE and HSPA+ WWAN.Share presentations, videos, and other content on a TV screen - no cables needed. Intel Wireless Display lets you connect your ProBook to displays and projectors wirelessly.Put in more face time. You're ready for web chats and conferences with Skype pre-configured on your HP ProBook. It's almost as good as being there.
HP ProBook 455 G1 Notebook - 15.6" - AMD A10 - 5750M - 6 GB RAM - 750 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8 Pro) + Windows 8 Pro Licence
AMD A10 5750M / 2.5 GHz, up to 3.5 GHz / 4 MB Cache
6 GB DDR3L (1 x 4 GB + 1 x 2 GB)
Storage
750 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
AMD Radeon HD 8650G
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet
6-cell - up to 7.5 hours
Security
Fingerprint reader
37.5 cm x 25.6 cm x 2.9 cm
2.4 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Recommended Use
Small business, corporate business
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8 Pro) + Windows 8 Pro Licence
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
L2 - 4 MB
64-bit Computing
Chipset
AMD A76M FCH
RAM
6 GB (1 x 4 GB + 1 x 2 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz / PC3-12800
Rated Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
750 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed - tray
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
HD anti-glare
Audio & Video
Graphics Processor
AMD Radeon HD 8650G
Camera
Video Resolutions
1280 x 720
Sound
Stereo speakers, stereo microphone
Codec
IDT 92HD91
DTS SOUND+
Input
Keyboard, touchpad
Numeric Keypad
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Bluetooth Class
Class 2
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP 2
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.3az
6-cell Lithium Ion
47 Wh
Run Time
Up to 7.5 hours
AC Adapter
Input
Output
65 Watt, 18.5 V
Connections & Expansion
VGA , 2 x USB 3.0 , 2 x USB 2.0 , HDMI , Microphone input , Headphone output , LAN
Memory Card Reader
Yes (SD Card, Memory Stick, SDHC Card, SDXC Card, Memory Stick XC)
Software
Software Included
Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, EverNote, HP ePrint, HP Hotkey Support, PDF Complete Corporate Edition, HP Wireless Hotspot (free download), HP Client Security
Case Material
Aluminum
Security
Fingerprint reader
Security lock slot (cable lock sold separately), HP 3D DriveGuard, HP Drive Encryption
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT
Localization
2.4 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance
40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
